exhaust Qustion
Old Dec 15, 2006 | 07:47 PM
nmf's Avatar
nmf
exhaust Qustion
Would like to know if someone can tell me what it would cost to have exhaust installed. I want to get turbo back for my 2005 and see good prices online but then you have to have installed.
Old Dec 15, 2006 | 07:54 PM
derek.mckay's Avatar
Get you a good Silverline T304 (lifetime warranty) turbo back, or whatever you can find and want and install yourself...it's a simple unbolt and bolt on procedure...save yourself the 3-500 bucks that someone else would charge you to install it...get a buddy and do it in an hour or two...just my two cents
Derek
Old Dec 15, 2006 | 08:36 PM
Cowboy 6's Avatar
Derek
Absolutely. What you want to do is nothing a case of beer won't cure. Just don't let your buddy (s) drink it before they are done!
Old Dec 15, 2006 | 08:54 PM
rodsram's Avatar
Yep,
must agree, you will need a buddy. I paid $86.00 to have a muffler delete pipe installed today, needed to be welded though, I thought it was quite steep as I had already removed the muffler, all that needed to be done was the welding and adding two hangars.
Old Dec 15, 2006 | 08:55 PM
Cowboy 6's Avatar
Originally Posted by rodsram
Yep,
Why did it need welded?
Old Dec 15, 2006 | 09:02 PM
nmf's Avatar
nmf
Well that sounds good but do not know if I can get done and do not want any problem. They will have to take off hole exhust and install from trubo back will have no cat just muffler and pipe.
Old Dec 15, 2006 | 09:05 PM
I know brother...I don't have a kitty anymore either...just a new 4" down pipe from the turbo (v clamp is the ONLY pain in the butt about the install) and a 6" flow through muffler, then on out the end with a 5" tip...looks and sounds great...and it's still an easy install, like I said...get ya a buddy and go to town. It's honstly nothing that you can mess up...long as you can loosen and tighten bolts, you can install an exhaust.
Derek
Old Dec 15, 2006 | 09:07 PM
PS, where are you from? Fill in your signature...I bet that you could find somebody on here near you that could help a bit if you didn't feel confident doing it yourself...
Derek
stock03's Avatar
It's really pretty easy. The hardest part will be removing your old system. Also, installing the down pipe with the "v-clamps" (I think that's what they're called) can be a PITA. But I did that with most of the horizontal portion attached to the down pipe. If it’s just a down pipe, then no prob.
Old Dec 15, 2006 | 09:19 PM
03whitedually's Avatar
I agree the band clamp or v clamp is a major PITA , i spent 4 hours just trying to get that back on , granted i was in my gravel driveway on my back , if i had a lift it probably been easier
Old Dec 15, 2006 | 09:24 PM
the downpipe was the first thing that I put on and ended up having to actually BEND the hangar piece on it a bit to fit into the hole AND still be able to fit into the v band clamp...then I tightened it down, went back and hung the muffler, then put all the rest of the pieces on last...PITA is right on the downpipe
Old Dec 15, 2006 | 09:38 PM
stock03's Avatar
BTW, are you upgrading to a 5" system? You already have a 4". Thought of just getting a new muffler? Or straight pipe? Just some thoughts. It would save you some money.
oh yeah, and I took off that transfer case protector all together...made pulling the OEM off MUCH easier
Derek
Old Dec 15, 2006 | 09:43 PM
stock03's Avatar
Derek
I should have done that. Instead I spent too much time trying to twist the old system out.
Old Dec 15, 2006 | 09:46 PM
I did the same thing...so don't feel bad. i spent about 30 MINUTES just trying to pull those OEM pieces apart ...DC really topped the cake when the clamped those things up like they did...100% unecessary
