Exhaust manifold
Old Apr 22, 2016 | 04:14 PM
Bradyram's Avatar
Exhaust manifold
I have a 2003 5.9 that I'm about to do some upgrades to .... Injectors , turbo , head studs , Fass fuel system , 5" exhaust , etc.
Question is , if it would be beneficial to upgrade the valve springs and also go with a steed speed manifold ?
Old May 1, 2016 | 07:47 AM
Dustin Dotson's Avatar
Lots of factors involved in determining whether or not you need the springs. Like whether or not you're going to choose to put a bump stick in it, or what turbo you wind up with. ( no pun intended) The FASS pump, and exhaust manifold would be the first two pieces I'd buy if I were buying pieces at a time. The manifold will give you more throttle response and spool down low. But I'm a firm believer in an aftermarket lift pump filtration system for even a stock truck that will never be modded. Good luck with it. Bomb on.
silkywoods
35
Feb 6, 2008 12:40 PM
Dusty Ratcliff
Apr 2, 2006 11:08 PM
Marine
Oct 5, 2003 03:45 AM
texasdave
Nov 8, 2002 08:25 AM
