Error Codes!!!
Error Codes!!!
I was headed to work yesterday morning everything was running fine, then my truck started to accelerate on its own and idling funny, sounded almost like the old 24v's. I shut her down sat there a minute started back up had these 3 codes p-0514, p-0192 and p-0633.. Tried the search could not find my codes.
The first two codes are not going to be from having a quad product on your truck.
P0633 Immobilizer Key Not Programmed - ECM/TCM
P0514 Battery Temperature Sensor Circuit Range/Performance
This fuel rail code will cause your truck to act up, you most likely lost a connection somewhere with the fuel rail sensor.
P0192 Fuel Rail Pressure Sensor Circuit Low Voltage
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
