Engine colder than air?
Old Nov 28, 2007 | 10:41 PM
Homer S.'s Avatar
My commander coolant temp usually reads 15deg or so cooler than the outside air before I start the truck for the first time of the day. Is this common? Should I add 15 or whatever to everything it says? Normal warmed up temp shows about 180-190 not towing.
Old Nov 28, 2007 | 10:45 PM
chrleb1's Avatar
A lot of times the sensors are not calibrated on the low side. They are meant to be accruate on the high side.
Old Nov 28, 2007 | 11:08 PM
CamperAndy's Avatar
That is a bit of an oversimplification. 15 degrees a significant error percentage wise on the normal scale of the coolant temperature. I also doubt that it is a linear error so you can not just add the noted error to the actual reading to correct. I would have it checked.
Old Nov 28, 2007 | 11:28 PM
Fast Tommy V's Avatar
Its possible that everything is reading fine. Since you are starting it in the morning the coolant reservoir could actually be cooler then the ambient air. Basically, the coolant temperature can still be representing the colder air from the middle of the night. Air warms alot faster then water does... I guess it all depends on the time that you are starting up the truck and how much warmer it currently is from overnight low.
Old Nov 28, 2007 | 11:55 PM
Homer S.'s Avatar
Good point, but it usually reads lower than the overnight low temperature.
Old Nov 29, 2007 | 07:26 AM
jrussell's Avatar
FWIW my SPA EGT and tranny temp gauge usually read exactly the same first thing in the morning, which is right around the ambient temp.
Old Nov 29, 2007 | 07:35 AM
tcr's Avatar
tcr
Mine do too, but my ECT on my Quadzilla(this morning) read 36*. The outdoor temp was 47* or so. I've heard from Quad the same as what chrleb1 said, the sensors are designed to be more accurate in the range we need them most.
Old Nov 29, 2007 | 09:10 AM
homewrecker's Avatar
The normal warmed up temp you listed seems low to me. Mine has always been in the 200-205 range
crobtex
Jan 6, 2010 04:31 PM
supersonictoys
21
Jun 28, 2009 09:05 PM
Forrest Nearing
Nov 9, 2004 10:29 PM
bkay
Dec 7, 2002 07:58 AM
