egt's runnig hotter than normal (even on stock)
My egt's are running about 200 deg higher than they normally do under normal driving conditions its also taking longer to cool down to 400 before i shut her down all other guages are reading normal anybody got any ideas.
thanks for the advice im gonna pull the probe and look at it i dont think its a boost leak i cant hear anything that sounds like a leak and the boost will still hit about 28 psi with that stock charger
Not sure how long you've had the truck / guages...if either is relatively new, could just be the ambient temp change. My EGT's are definately up as it's 100* here in Phoenix....hotter egt's when accelerating and longer wait for shutdown...cruise isnt too much higher...definately a big change between winter / summer in my area.
What transmission do you have? any upgrades?
yeah the temp has def changed in the past few weeks it was in the 90's today that could be the prob i bought the truck new in 05 and had the gauges about 2 months after i bought it. the tranny in a full billet hts i just put in last weekend
what if it is a injector i was planning on get some flux's anyway but i guess there is a big waiting list on them or so i have been told should i not drive the truck till i get injectors if that is the prob
28psi is low for max boost on an '05 with a stock charger. You sig says you have a BDTD and an MP-8. You should be seeing over 40psi max with those turned up.
I got mine back from Don last week. He received them wednesday and shipped them out the following tuesday. Not too bad considering how long people wait for other vendors.
yeah i thought the boost would be higher to im suppose to get my silverbullet at the end of the week so im not real worried about it what dealer did you use when you did your injectors cause that would be sweet to get them back in a few weeks time.
