EGT Probe Location ?
Old Jul 31, 2004 | 07:07 PM
lucey's Avatar
I've seen a couple of different locations for the EGT probe location. On one diesel power products website they put the probe on the top of the manifold as shown in their downloadable pdf files. Another location was where all the exhaust ports joined in the collector and enter the turbo housing. What is the best spot for the best results, or are they the same. The top location would definately be the easiest but is it correct ?
Old Jul 31, 2004 | 09:36 PM
chuckr72's Avatar
i put mine in the manifold, which is where most people put them. from what ive been told this is the most accurate place to put it. hope this helps.
Old Jul 31, 2004 | 11:05 PM
lucey's Avatar
Manifold ?
By manifold do you mean the very top or down in the collector approx 2 inches above the turbo ?
Old Jul 31, 2004 | 11:28 PM
AK RAM's Avatar
Right side versus left side probably matters more to most folks. The general consensus is that the back three cylinders will run the hottest, so most people want to make sure they are monitoring those. The collector has a solid divider in it that runs right down the middle, so you want to put it off-center, slightly to the left so you measure the hottest side and don't drill into the divider. Whether you do this from the top or the side is more of a personal preference. From the top is definitely easier (check my gallery pics).
Also, depending on which probe you have, it may not fit in the side. Some are longer than others. The probe that came with my X-Monitor is really long and just holding it up there for an eye test, it was obvious I had no choice but to go down from the top. It was longer than the collector was wide.
Old Aug 1, 2004 | 12:44 AM
SjLingenfelter's Avatar
Ive also heard the the best place is right before the flange where the header and turbo meet.
Old Aug 1, 2004 | 12:55 AM
SuperGewl's Avatar
As they have all said it depends on the application. Banks says to install it in the after portion of the exhaust manifold. I have one the exhaust manifold and one in the exhaust pipe after the turbo after the down elbow. Gotta love those BOMBS
Old Aug 1, 2004 | 09:59 AM
Maccandy's Avatar
SuperGewl
How much difference in temp. do you see in the two?
shortydodge
19
Feb 3, 2008 12:54 PM
jon05ctd
Sep 9, 2006 09:55 AM
59FORD
Apr 7, 2006 12:28 AM
cquestad
Mar 4, 2004 02:26 PM
Drafter
Apr 16, 2003 10:58 AM
