Edge Upgrade 440Ft/Lbs!!
Old Mar 6, 2007 | 11:18 PM
3500lly's Avatar
Agreed, the pump and tranny IMO are the weaker aspects to these trucks.
Old Mar 7, 2007 | 04:18 PM
jboIND's Avatar
973604x4-
Those are very good numbers. MP8 basically does the same thing as EZ right? Thing is I have an EZ and would like to stack it with a Smarty or Hot Juice. I like the Edge b/c of the safety features with the monitor. But since I already have gauges and don't really need the monitor I lean back towards the Smarty. Been tryin to decide for almost a month now. Can you run the Hot Juice/EZ stack on a stock turbo? My tax return isn't enough for everything I want so a turbo upgrade might be a couple months away(maybe longer). Thx for the response .
Old Mar 7, 2007 | 06:23 PM
omaharam's Avatar
Originally Posted by jboIND
973604x4-
Yes. You just have to keep a close eye on your egts. They will spike up there, just make sure they aren't high for too long. I wouldn't be surprised to see 1500+, but if it's only for the last second of a run, it should be ok.
Old Mar 7, 2007 | 06:26 PM
nfsommer's Avatar
440 ft lbs.. lol, that would be good
Old Mar 7, 2007 | 07:21 PM
jboIND's Avatar
Thx omaha. What kind of EGTs/boost #s did it read on your dyno run/runs?
Old Mar 7, 2007 | 07:28 PM
Monkey 456's Avatar
So with a stock trany on a 03 juice with attitude will it hold ?
Old Mar 7, 2007 | 07:43 PM
Lark's Avatar
Originally Posted by skynyrd
well since scotte chimed in earlier i guess i better pop my head in here. on level 5 regular juice i could slip the TC but with the hot juice the tranny can't hold even in level 4, level 3 is even pushing it with the ez on 1. but i'll tell you this a fuel pressure box does help with the lower end with the juice. the hot juice upgrade is definitly well worth it.
Are you saying once the Hot upgrade is done, it's adding more power to the lower levels as well?
I'm just wondering what changed with your levels 3 and 4 after the upgrade was done?
Old Mar 7, 2007 | 08:25 PM
Mav's Avatar
Mav
Originally Posted by 973604x4
480's....wasn't me though. That seems really low though....Omaharam did 500hp with his Hot Juice/MP8. We'll see what my Hot Juice + XZT + water/meth does here pretty soon.
its too much for a stock lift pump.....i can tell you that much
Did you ever install the water Meth?
Old Mar 7, 2007 | 08:34 PM
omaharam's Avatar
On an 06 you get a 6th level. On an 05 and older, you lose the 25hp level, so level 1 is now 40 instead of 25 and so on.
Old Mar 7, 2007 | 09:51 PM
973604x4's Avatar
oh my lord we got it working correctly tonight....all 4 295 nittos spun at a 10psi launch. it MOVES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
be watching for a thread on this later this evening.
Old Mar 7, 2007 | 09:58 PM
Mav's Avatar
Mav
ight..........hurry lol
Old Mar 8, 2007 | 06:24 AM
omaharam's Avatar
I was getting 40psi on the dyno. I get about 42 on the street and a spike to 45-47 when it hits OD. I wasn't watching egts on the dyno. On the street ( I mean on the track - aheem ) in 1/4 mile run it hits around 1300 without the water/meth on. Now that I've been playing with the predator downloader in the mix, it will go over 1400 by the time I hit 90mph or so. I haven't actually made a full pass yet. I also haven't used the water/meth injection since I got it working again. The weather here has been bad, but suppose to clear up starting today. So hopefully I'll get to play around this weekend.
Old Mar 8, 2007 | 06:26 AM
omaharam's Avatar
With the standard Juice, I could slip the TC on level 5 with stock stuff. I did the TC/VB at the same time as the HOT upgrade. I wouldn't run more than level 4 on the standard Juice with stock tranny.
Old Mar 8, 2007 | 06:32 AM
jboIND's Avatar
Have you tried the Predator extreme stack w/ Hot Juice? Most ppl running that stack have 305s. Lookin for some feedback on the 325 thx.
Old Mar 8, 2007 | 06:57 AM
omaharam's Avatar
That's what I have loaded right now. With no fuel additive, it has a lot of rattle. With some powerservice, it has less rattle. I'm going to fill up today after work with a stronger dose of powerservice or gen49 if any of the local shops carry it, and see what that does for the rattle. It definetaly hauls and it smokes like a coal train. I was messing around the other day and actually made a car stop in traffic - oops. I will be dynoing on the 18th and will post results on the thread "the morkable stack on an 04.5."
