Edge and Smarty Gurus?
Hey guys I have done alot of research on here about the edge and smartys. My question is if I leave my attitude connected and on stock just use the guages. Will the smarty be ok and do you think I will gain alot with the smarty? Also what settings are you guys running the smarty on? I tow sometimes not alot but sometimes and it with the trailer maybe 13000lbs. Thanks for your input.
The SMARTY will be ok and yes it should put down some nice #'s
CRAFTY,
fill out your signature (toward the top of the page on the left under User CP) for us so we can help out with your specific application.
You need to fill out a signature so we know what truck and mods you have.
My experience with the Juice/Attitude and Smarty stack was not a good match. Some run it ok, but the Juice/Attitude does not have enough explict settings to get a good match for timing with the Smarty.
That said if you set the Juice/Attitude to stock it should work fine as gauge monitoring. You will see better results from the latest Smarty versions than you do on the Juice/Attitude.
ptgarcia
Jan 4, 2007 06:14 PM
duallydave
Jan 3, 2007 01:26 AM
