EDGE revolutionizes with EVOLUTION
Old Mar 26, 2007 | 10:52 PM
PEAKSTRYDE's Avatar
WOW!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Clicky to See
What an awesome new product!!
(Scroll down to Chevy / GM applications to see a list of all the availabe monitoring peramiters)
NOW, when are we going to see them for our trucks?????????????????????
Old Mar 27, 2007 | 08:00 AM
CTDjoey's Avatar
So thats a programmer and a monitor for 600? Am I reading that right? Sounds like a pretty good deal to me.
Old Mar 27, 2007 | 09:20 AM
abc4yew's Avatar
For fords that is guilding the Terd. Good on a 7.3L though ks
Old Mar 27, 2007 | 09:32 AM
PEAKSTRYDE's Avatar
Yes, that is right!!!!!
It is a downloader and I believe the monitor plugs into the diagnostic port and reads from there..............
Also I think the ONLY under-the-hood wiring is an EGT probe...........................
Old Mar 27, 2007 | 12:01 PM
ptgarcia's Avatar
If it reads from the diagnostic port it won't read accurately if there is any kind of "fooling" going on.
Old Mar 27, 2007 | 01:44 PM
973604x4's Avatar
maybe im missing something, if i am correct me....but isn't that just like the Bullydog with Outlook combo?
Old Mar 27, 2007 | 06:37 PM
PEAKSTRYDE's Avatar
Can you give me a link that shows all of the Bullydog monitoring peramiters????????????????
Please
Old Mar 27, 2007 | 06:48 PM
973604x4's Avatar
Please
Heres the Outlook
http://www.bullydog.com/shopping/pgm...age_num=1&=SID
Here's the new PMT
http://store.dieseltruckresource.com/bullydogpmt.html
Here's Edge's top of the line monitor
http://www.edgeproducts.com/product.php?pk=46&pvk=118
I don't see whats soo special about the product you reference? if i'm missing the boat here, please point it out to me!
Old Mar 27, 2007 | 08:39 PM
PEAKSTRYDE's Avatar
The Bullydog doesn't even begin to compare with the options that the Evolution has. Here are both of the lists for camparison. The BD does not really give (explain) all the peramiters like Edge does.
EVOLUTION:
ADVANCED TUNING
• Speedometer correction (corrects for trucks tire size)
• Adjustable speed limiter
PERFORMANCE TESTING
• 0-60 and Quarter mile performance tests with the drag strip Christmas tree lighting and reaction times
DATA STREAM
• Records 5 parameters for up to 60 seconds
• Viewable graph using available software
PIDS
The Evolution allows the user to view up to 4 PIDs at one time. There are 24 different PIDs to choose from. Below is a list and description of each:
• RPM (Revolutions Per Minute) – Engine speed.
• MPH (Miles Per Hour) – Note: Dash display may be +/-3 MPH off from the digital display due to mechanical differences in the spring, etc. used to control the gauge.
• ECT (Engine Coolant Temperature) – Degrees F.
• LOAD (Engine Load) – Calculated engine Load
• GEAR (Current Gear) – Current gear.
• TFT (Trans Fluid Temperature) – Degrees F.
• BST (Boost Press) – PSI
• MAF (Mass Air Flow) – Grams Per Second
• IAT (Intake Air Temperature in manifold) – Degrees F.
• DFRP (Desired Fuel Rail Pressure) - PSI
• AFRP (Actual Fuel Rail Pressure) - PSI
• OSS (Output Shaft Speed) - RPM
• MAP (Manifold absolute Pressure) - kPa
• MIT (Main Injection Timing) - Degrees
• TQ (Engine Torque) – ft/lbs
• BAT (Battery voltage) - Volts
• CFR (Calculated Fuel Rate) – mm3
• VPOS (Turbo Vane Position) - %
• APP (Accelerator Pedal Position) - %
• IATT (Intake Air Temperature in intake tube) – Degrees F
• BARO (Barometric Pressure) - kPa
• FTMP (Fuel Temperature) - Degrees F
• DIDL (Desired Idle) - RPM
• EGT (Exhaust Gas Temperature) – Degrees F
Bully Dog PMT unit features:
* Down loader& In Cab monitor
* Adjustable on the fly performance levels
* Color Touch Screen
* Internet upgradeable
* Nitrous Interface and Propane Interface
* Multiple Mounting Positions
* Quick Release Cradle
* Interfaces with Customer PC
* Graphs and Upload Personalized Backgrounds
Safety Features
* Pyrometer De-fuel
* Transmission Temperature Protection
* Oil Temperature Protection
* Coolant Temperature Protection
* Cold Engine Protection
* Boost Protection
Benefits:
* Monitors Multiple Vehicle Functions
* Controls Multiple Vehicle Functions
* Performance Tuning Capabilities
* Transmission Tuning
* Displays and records vehicle performance tests
Old Mar 27, 2007 | 11:07 PM
ptgarcia's Avatar
Half the stuff the Edge displays is pretty lame. RPM, speed, tranny gear...I don't need the Edge to tell me that.
Old Mar 27, 2007 | 11:10 PM
973604x4's Avatar
plus half the stuff they advertise is on Fords and Chevys....not Dodges. I experienced that with the A2 i used to have.
Old Mar 27, 2007 | 11:12 PM
Luvnacumns's Avatar
How does this revolution read these paramaters if it plugs into the usb port most of it aint going to be true readings anyways!! There are pro's and con's to each..
EVOLUTION:
ADVANCED TUNING
PERFORMANCE TESTING
DATA STREAM
PIDS
Safety Features
* Pyrometer De-fuel
* Boost Protection
Benefits:
Old Mar 28, 2007 | 12:42 AM
tacook's Avatar
Its not even released for the Dodge and I see post after post saying its not going to be accurate...........how the .... do you know? Do you have this unit installed in your vehicle? Have you compared the unit with a set of analog gauges side by side? didnt think so. Maybe it is garbage, I dont know, but facts would be nice. I think it has the potential to be a nice unit, gauge set and programmer all in 1 unit with the mount included. Good luck finding a USB port in your truck.
Old Mar 28, 2007 | 08:25 AM
Luvnacumns's Avatar
My bad.. Diagnostic port... Besides owning an outlook comparted to anaolog guages... Yep I've had them both. There is a difference!! Analog guages are hardwired into the source the odb port or USB port... is only a source to read from the diagnostics!... Sorry i am not a pro to give you your definated answer but it's common sense.
Shane
chance hood
0
Apr 19, 2015 09:34 PM
Tommy93w350
Nov 30, 2014 06:56 PM
sallyman1
Jan 24, 2008 05:11 PM
31
Dec 14, 2002 11:05 PM
