edge chip
edge chip
just put an edge juice with attitude in my 2003 cummins 1 ton dually. i like it alot. just wondering what else you guys recommend to put on? exhaust? air intake?
also i thought my truck would throw a little black smoke in extreme !? doesnt really do that
still think its an awesome chip.
thanks
thanks
Have you adjusted you're low boost fueling? Go into you're juice settings and select the low boost fueling for it and set it to 5 for max fuel at low boost = smoke. I have mine set lower (Tow setting with it at 3) but it also helps with towing and EGT's. Play around with it and you'll find the settings that work the best.
gergthegreat
Dec 30, 2008 09:19 PM
bansh-eman
Jan 27, 2008 02:48 AM
Elk_Hunter
Oct 24, 2006 03:17 PM
