EBC brakes = more dust & noise
I have the EBS Severe duty 7000 pads and EBS slotted / cross drilled rotors on all 4 corners. Have put about 40,000 miles on them. All I can say is money well spent!!! NO dust, NO squeal, and NO affiliation with EBS!!!!!
The truck just rolled 226,000 today, (2003 2500 HO 6spd)
-I'm on 3rd set of brakes
-4th set of tires
-front wheel bearings @ 170k
-NO other repairs.....just upgrades & service (oil changes etc,,,)
Tst, Smarty, super B turbo, Donaldson, AFE with modded stock air box, gauges
-4th set of tires
hey annabelle, my rotors are fine, i will take a pic of the pads, i bought the pads in December of 06 so i had them on my truck for 5 months i had put 3000 miles on my truck and the are done for, so i went with the OEM pads, got them for a good deal from my buddy who is a parts manager at Dodge.
Guest
Posts: n/a
I've got over 2000 miles on my EBC Yellow Stuff pads and so far I'm very disappointed. Tons of dust and the squeal is annoying as heck! Excellent stopping power but the other stuff is a big downer. I'm considering writing to them and either getting my money back or asking for a replacement set just to see if I got a lemon set.
yeah my EBC Yellow Stuff didnt last an oil change. i am gonna contact EBC as well. i have chrome wheels and due to ungodly abount of brake dust my chrome in certain areas has discolored and faded. and this fading and discoloring only happened on my front wheels, i had O.E.M brake pads on the back and my wheels look fine, no discoloring, this discoloring did not take place until i switched from O.E.M to EBC. so i will call them and see if they would be able to due something, i expect they wont do anythining but its worth a shot, maybe i can get them to pay for powder coating my wheels black, whatever, i think the compound is to soft, hence the stupid amount of brake dust, i could not keep my front wheels clean, in three days time my wheels were black, not to mention the how noisey they were, they made way more noise when the break in coating was on, and i did what there instructions said. in my opinion i would recommend against them.
I've got about 2500 miles on Front Yellow EBC pads, and Rear Green Pads. The Green pads in the rear have put off little to no dust. The yellow pads have put off a tremendous amount of dust, but I have not had time to clean them, so I have no way of knowing if they are still painting the wheels black. Cleaning the truck is on the list for Friday, so I'll report back on this in a week or so.
I had a little bit of squeeling in the first 200 miles, but since it has gone away. I did use High Temp anti-seize on all metal to metal contact. Braking feels relatively the same as stock. I had all 4 stock rotors turned. I drive a hand shaker, so I'm not as hard on brakes anyways. Possibly a little bit better than stock, but I have no way of knowing for sure.
I put the Green pads on all four corners of my wife's Sebring, and they have been awesome. A little bit of dust on the front, but definately a noticeable difference in stopping power.
Overall, I am not overly wowed by the pads, but I do not regret putting them on either. The big decider for me will be longevity. And hopefully it will be a long time before I can report that....
As a side note, my stock brake pads and rotors were actually in decent shape @ 30,000 miles. However they were squeeling like crazy, and would not stop no matter what I tried. THe only thing I did not do was turn the rotors to make it go away, b/c at that point it was worth replacing the pads anyways since it was all apart.
It wasn't so much a concern at the time of buying them. Now it is just the decider on whether or not I'm happy with the purchase since they feel so similar to stock. If I get 10,000 miles outta them, then yes I should have bought stock. If I get 100,000, then I am happy with them. As far as people looking to buy them in the near future, I am just unable to give a definate approval/disapproval. Thats unfortunate though, b/c whenever I put something new on my truck, I hope for the 'holy stuff!', this upgrade is awesome. I didn't get that with these pads. I'm almost curious enough to buy a set of Hawk pads for the front, and throw them on to compare and see if there is a huge difference. However, I'm guessing that upgrading the rotors would probably help a lot too, but thats a lot more green than I want to throw down when my stock rotors still have many miles left on them.
Guest
Posts: n/a
Mine were squealing so bad today that as soon as I got home I fired off an email to EBC. I explained my situation and I'm asking them to please either send me a new set, replace them with a different type of theirs that may be better suited for my truck or to refund my money. I can't handle all that noise and it's embarrassing as..... well you know. I'll post their response when I hear from them.
Guest
Posts: n/a
Well here is their response:
When you installed the pads did you also replace the rotors or did you
have
the rotors turned to remove any transfered material from the previous
pads?
The carbon metallic material found in most other pads is not compatable
with
EBC's Kevlar Aramid fiber material and can cause squealing.
Simply putting on a new set of pads will not solve the problem if this
is
the case.
Also, did you also replace the rear pads at the same time?
Often the higher friction rating of the EBC front pads requires the the
rears to compensate by applying extra force on the rotors which can
cause
glazing in the rear pads and consequent squealing. This is why we alway
recommend replacing the front and rear pads with similar friction rated
materials.
sounds like a crock to me. What do you guys think?
have
pads?
with
is
the case.
cause
materials.
-4th set of tires
-4th set of tires
Richard
I have a previous post on the subject
SmittysRam
Sep 2, 2010 09:24 PM
merrillr4
0
Dec 14, 2006 01:07 PM
angleiron
Oct 27, 2006 10:03 PM
