DZILLA calling QZILLA! DZILLA calling QZILLA!!
Or anybody else using a Quad Std box....
I mistakenly knocked my switch off the end of the plug and I'm not sure which set of pins it plugs into. The plug has 4 pin holes but the back of the switch has 6 pins. I just don't want to use the wrong ones and have any issues....
Help.....................................
If you look at the board closely you will see that it has LED and BOX are marked near the connector. You need to be on the side that says BOX.
Now you should be able to tell which way the connector goes but just in case the Green wire needs to be in the middle of the board and the white wire is on the outside.
Quad
Quad
I just brought the switch in to look at it. Of course I dropped it again on the way in and scratched it up!!!
I see what you mean now.
Thanks for the help. I really like the box. I just need to learn how to drive this 6-speed to get the most out of it. It seems you have to shift just as you feel the power coming on. If you wait too long then it over revs and then it's just no fun.....
I see what you mean now.Thanks for the help. I really like the box. I just need to learn how to drive this 6-speed to get the most out of it. It seems you have to shift just as you feel the power coming on. If you wait too long then it over revs and then it's just no fun.....
DodgeDemon
Jun 30, 2007 01:44 PM
MadFrog
Jan 24, 2006 11:06 AM
ramdez
46
Jul 26, 2005 11:29 AM
97CTD
Feb 24, 2003 05:00 PM
