dyno with/without exhaust brake?
Old Nov 25, 2007 | 02:28 PM
jlibert's Avatar
has anyone dynoed with and without an exhaust brake installed? I'll even take sotp dynos. At our local dyno event the exhaust / ventilation system popped off during my dyno run and the truck instantly spooled up. I couldn't help but to start wondering if my exhaust brake might be affecting performance a little.
thanks-
j.p.
Old Nov 25, 2007 | 11:17 PM
JCLeary's Avatar
thanks-
j.p.
I thought about the same thing. The PacBrake elbow is not a smooth arc like the stock elbow, or even the Jacobs elbow. I can't see it making too much of a difference, however. Not as much as that 4" pipe running up through the roof...
You could ditch the 4" elbow and install a 5" inline somewhere on your d/p. My bet is that you wouldn't see too much of a difference. I can't remember if you're still running a stock intake horn, but I would be there is where you'd see a difference.
I'll bring some tools to the next dyno if you want to try. I still have my stock elbow for you to use
Old Nov 25, 2007 | 11:24 PM
scootertrash35's Avatar
the jake vac pump has to kill a little power
Old Nov 26, 2007 | 09:19 AM
JCLeary's Avatar
PacBrake=No vacuum pump
It uses compressed air provided by an electric compressor.
Old Nov 26, 2007 | 09:39 AM
bnold's Avatar
I'm running a 4" inline pacbrake... Don't see how it could cause enough turbulence to cost HP... Don't think you would be able to see it on a graph.. Besides 2hp isn't worth ditching my brake!!
Old Nov 26, 2007 | 10:01 AM
note the word jake(jacobs uses a vac pump)
Old Nov 26, 2007 | 10:48 AM
jlibert's Avatar
thanks john, I have my elbow and some tools too. The pacbrake has been on before all of the mods, so I've never really been able to compare it to anything.
JaimeG
Mar 26, 2009 06:58 AM
Spooler
Sep 30, 2007 02:35 AM
Lightman
Feb 16, 2005 08:50 AM
Andyinchville
Jan 10, 2005 06:22 PM
