Dyno Numbers
Old Apr 25, 2006 | 11:43 AM
DodgeZ's Avatar
Dyno Numbers
What are you guys seeing stock? Are they pulling close to what they are rated. I know my old Hemi truck would only pull 280ish and it's listed 340hp at motor. My SRT4 will dyno 215-220 and it listed as 215. So are they underated? My brother in-law has a new F350 and he dyno'ed at 422whp after mods. Just wondering how much I'd need to stay ahead.
Old Apr 25, 2006 | 01:55 PM
TexasCTD's Avatar
If you go dyno your truck on a dynojet.........Stock....you will probably see about 270-280hp and 500-550lbs torque.
Who knows what you will see if you dyno on a Mustang.
Old Apr 25, 2006 | 03:32 PM
BRayls's Avatar
on a mustang with a good operator you will see the same numbers. the one you guys had unreliable numbers from I would stay away from.
Old Apr 25, 2006 | 03:36 PM
qzilla's Avatar
You will see the same numbers on the same Mustang. They are very reliable and work well. With each different model you will see different results. If you use a Mustang, just go back to the same one, you cannot flop around.
Quad
Old Apr 25, 2006 | 03:41 PM
DodgeZ's Avatar
I was hoping it was underated like my SRT. Oh well.
Old Apr 26, 2006 | 04:29 AM
TexasCTD's Avatar
The 325hp/610tq rating is at the flywheel.........so there will be some driveline loss thru the tranny, driveshaft, rear axles...etc.
Don't worry though, you can turn that Cummins into a beast if you build it up right. You will have no problem smoking your brother-in-law in the F350 if you spend the money in the right areas.
sCreamin400
Nov 2, 2008 01:46 PM
Fillerupsonny
Sep 10, 2003 12:53 AM
moneyman
Jun 1, 2003 11:06 AM
Diesel Dave
Jan 10, 2003 12:08 PM
GO 4LO
Jan 3, 2003 05:44 PM
