dually spacers
Old 07-22-2004, 10:16 PM
Big Bob's Avatar
My fender flares are the standard Xenons which are made for SRW Dodges. I bought them off the internet on Ebay for about $280.
Here is the vender I bought mine from.
The reason I went with the Xenon's is because that are more flexible and have 3M tape that hold the top of the flare to the fender. It does take at least 2 people, some time, a little shimming and alot of patients. The inside of the fender flare that is suppose to attach to the inside top of the wheel well. We had to add about 1/2" plastic shim, then installed the bolt through the fender flare, through the shim and then through the fender and attached the nut. Make sure you follow the instruction exactly for painting! This is very important.
Let me know if you have any questions.
Big Bob
Old 07-23-2004, 09:08 PM
Ramasaur's Avatar
Thanks for the info.
Old 07-23-2004, 10:24 PM
SjLingenfelter's Avatar
Hey Ramasaur if you do turn your truck into a SRW would you sell the spacers or keep them for another truck? And did you ever find the website that you got them from?
Old 07-24-2004, 09:34 AM
Ramasaur's Avatar
If I switch over to SRW I will be selling the spacers and the dually fenders. I cannot find my receipts for the spacers, but I believe I got the from Performance Wheel in CO.
Old 07-26-2004, 05:04 PM
Ramasaur's Avatar
gdh11.....
Some answers to your Q's:
1. You don't and shouldn't have any type of spacer in the front w/ exception of the stock dually hub extender that is on every dually front end.
2. The only Co. right now is Eagle wheels (see my pics- rear duals) for 17inch
3. I have 285X70 (33X11.5) with 2" rear spacer
4. Nobody makes anything wider than the 6" wide dually wheel in a 17 inch....
Hope this helps
Old 07-27-2004, 09:32 AM
I would think the spacer goes in between the inner and the outter. Cause if you put it on first then put both tires on all your doing is pushing BOTH tires out instead of the outter tire. Does that make sense. Kinda confusing.
Original Junior
05-17-2006 09:45 AM
harry j holcomb
02-20-2006 08:20 PM
nauitque21
06-06-2005 10:48 AM
scarecrow
03-09-2005 09:04 PM
Quick Reply: dually spacers
