dually ??? 315
I bought my wheel spacers from Stockton Wheel, at the time nobody else I contacted were making any for our trucks, I tried several vendors. The spacers I bought were dropped shipped from Arrowcraft,(the aftermarket dually conversion people) even though I bought them through Stockton Wheel. They are solid steel and are heavy and expensive if you ask me. I paid $500 for my pair. You may be able to get them cheaper if you go through Arrowcraft directly. There are a couple of issues you need to know if you buy the ones I did. First you will have to buy new lugs to hold the spacer to the truck because the factory ones will not work due to the built in shoulder/washer. You should be able to get those at any parts store. Second is that the lugs they supply for their studs on the spacer are both larger than the factory hardware so you will have to ream out the bolt holes on the outer 2 wheels, they do include a reamer bit for this. Also note that since the new lugs are larger than the factory ones that your inner hub cap will not fit on the new lugs. I know other people on this forum used different spacers and did not have the hub cap issue I did. I did not know this until after the fact.
Johnny
Johnny
Zeus
Aug 25, 2006 09:46 AM
CCOUGHRAN
34
Oct 16, 2004 12:31 AM
MNISB
Dec 5, 2003 07:40 PM
