dual line from CP3 to rail
other than a hose and fittings that will handle 30 000 psi what else is included in these kits? Is this not something I could just have made up localy at a hose shop???
The I I second supply line is a custom jobby from Europe....But it is a flexible line. If you have a Diesel Fuel Injection repair shop locally they could probably make you up a rigid supply line that will work for you....30,000 psi is a whopping amount of pressure to mess around with. ks
Syn. The rail line is made from Parker polyflex 2440D-03U37 4.7mm, 3/16". The fittings on the ends are two females the same as what fits on the CP3. the clamping surface of the fitting is 50mm or 2 inches long and has 8 compression marks then it was ground down in a couple of spots for some reason....maybe had the company name on it or something. Then there is one adapter to take the female to a male that fits in the pressure relief threaded hole. The diameter of the hole is about the same size as a pen refill.....tiny for the size of the line....pretty much the same as the relief valve. The line is 33" long and the adapter adds another inch. I just checked the invoice and freaked. $250 for turbo housing $350 for dual line
....then I remembered I got a custom ATS manifold at the same time....the dual line was free with my Super CP3.4. Did you price the dual line kit at Ind. Inj. ? KS
no I havnt gotten around to really hunting down any prices yet. I have been too busy with the holidays and gettin back to work. I have only been able to post on here in the late eves when i have a bit of down time before i pass out for the night.
Thx very much for the info. I have a parker office close by so maybe ill check in with them.
RDR
27
Dec 23, 2008 07:34 PM
adamsmarshall
13
Oct 7, 2008 06:54 PM
Jethro6213
19
Jul 11, 2008 11:59 AM
UnrulyNFS
Aug 24, 2007 09:07 PM
BADBOWTIE
28
Jul 14, 2007 02:36 PM
