Dual cp3 problems
Old Jan 10, 2009 | 11:20 PM
travjrath's Avatar
Dual cp3 problems
Ok, helping friend out here guys- Got PPE Dual fueler kit installed and problems began right off- rail pressures were all over, truck has Bully dog on it and reflashed it and that seemed to cure it ...WRONG, on a short test drive the rail pressure spiked to 26K and stayed there. IDEAS???
Old Jan 11, 2009 | 07:44 AM
RyeThomas's Avatar
Winner winner chicken dinner!
Bad FCA on one of the pumps would be my first thought.
Old Jan 12, 2009 | 01:05 PM
paulb's Avatar
Is one of your CP3's a Durmax? What is your lift pump pressure?
Paul
Old Jan 12, 2009 | 01:20 PM
Don M's Avatar
DTR Advertiser
Dont drive it. Dont run it over idle until you get it fixed. Probably the FCA.
Old Jan 12, 2009 | 02:10 PM
Bad-Duvall's Avatar
X2 I had rail pressure all over blew up the cp3 and metal went all threw my system. Also FCA's will go bad from sitting with out use.
Old Jan 12, 2009 | 02:16 PM
cquestad's Avatar
or...bad rail sensor connection or sensor...
Old Jan 23, 2009 | 10:48 PM
travjrath's Avatar
was the rail sensor! Thanks guys!!
Old Jan 26, 2011 | 09:55 PM
jeepmodman21's Avatar
have any of you guys broken the high pressure lines with your twin cp3s? i blew 2 in the last 2 weeks, makes a hell of a mess and lines are 112.00 dollars a piece!!!!! my rail pressure is never over 23000 psiuntil i shut the engine off then they will spike to like 29k for a split second...they only ever break at highway speed though. Are you not supposed to run that extra flexible line from the stock cp3 to the top of the fuel rail? i also have an ATS Atomizer that i keep turned off now, not that it did much??? any ideas??? sorry for the long post. thanks
RDR
27
Dec 23, 2008 07:34 PM
adamsmarshall
13
Oct 7, 2008 06:54 PM
Jethro6213
19
Jul 11, 2008 11:59 AM
BADBOWTIE
28
Jul 14, 2007 02:36 PM
megacabrule
33
May 10, 2007 01:07 PM
