Dual Cp3 Install = Spiked Egts At Random
Old Jul 23, 2008 | 04:36 PM
Moobesor's Avatar
Installed a dual cp3 kit and now my EGT's spike up and down instantly while driving. They will be at 900 then bounce up to 1300*.
Other than that the truck runs great.
I believe it must be a bad connection. But where? I went through most of the connections and everything seems tight.
Rail pressure doesn't spike like the egt's. It goes up when I accelerate and goes back down when I let off. It seems normal.
The new belt squeeks. Any way to fix that?
Old Jul 24, 2008 | 07:24 AM
Moobesor's Avatar
Tries everything, egt's still crazy.
S-Belt may be too tight causing bearings to squeak?
Old Jul 24, 2008 | 10:01 AM
cquestad's Avatar
Squeek at shut down is normal with twin pumps...
I think it is cool!
Did you mess up your egt gauge wireing?
Old Jul 24, 2008 | 02:45 PM
zuki_dan's Avatar
A friend just did a turbo install and the EGT probe became faulty after removing it from the manifold. It sounds like yours was acting weird like the one I worked on. We replaced the probe and everything was fine again. The original probe was siezed in the fitting. It was an isspro setup also.
torkmnstr
17
Dec 28, 2011 08:41 PM
rednekroper05
Aug 6, 2009 10:45 AM
Jethro6213
19
Jul 11, 2008 11:59 AM
torkmnstr
17
Apr 21, 2008 07:14 PM
BADBOWTIE
28
Jul 14, 2007 02:36 PM
