Drilling and Tapping
Old Aug 16, 2005 | 05:56 PM
david_4x4's Avatar
Question Drilling and Tapping
So I'm gonna devote all day tomorrow to installing my gauges. I have pretty much everything figured out.
Just a couple of last questions.
When I'm installing the thermocouple, will it by itself be air tight enough not to produce exhaust leaks? I plan on applying some anitseize stuff and maybe that will help, but not sure? Same with the intake side.
Tranny Temp sender. Where should I mount this at? If in the pan, where exactly? I also saw a thread about placing it in some test port. Ideas?
Thanks In Advance
David
Old Aug 16, 2005 | 06:13 PM
4x4not's Avatar
The pyro probe is pipe thread, so it is tapered. It will seal itself. And yes, using 1500°F antisieze is a good idea.
No help on the tranny stuff
Old Aug 16, 2005 | 06:37 PM
swansong04's Avatar
Re: Drilling and Tapping
Thanks In Advance
David
well i have tranny temp sensor in my pan .. i went with a mag-hytec pan it has the thread hole for the sender all ready in it .. alot guys get a new transmission cooler line and put it in there they are avaliable at.. http://www.massdiesel.com/d24/amtransmission.htm
DO NOT !! use the test ports in the tranny , they don't give a accutrate reading of the fluid and you can cause damgae to your tranny doing so ... good luck ...
Old Aug 16, 2005 | 07:22 PM
TAS05CTD610's Avatar
I never heard of using the test ports as damaging.... I wonder why some companys actually recomend installing them there if it threatens the tranny. I've had mine there for a few thousand miles and no problem, however will move it to the pan once I get one (which may be a while) Anybody ever have problems with mounting it there? Other than it's not the most acurate.
Old Aug 16, 2005 | 07:47 PM
TRAVIST's Avatar
I have mine in the test port and have had no problems at all. Matter of fact this is where most gauge instructions will tell you to put it on the new trannys. As far as inacurate readings that is bologna as well. My readings are the exact same as the guy I work with that has the x-monitor for his gauge set up. IMHO the test port is the best and the easiest place to put the sensor as there is no cutting lines and no drilling holes to install.
just my .02
TRAVIST
Old Aug 16, 2005 | 08:54 PM
JPDiesel's Avatar
Head rest vid ?
Not to steal the thread just a quick question:
Travist- where did you get the vids for the head rest, I have been looking to get these for the kids as well.
Thanks
Old Aug 16, 2005 | 09:26 PM
david_4x4's Avatar
So placing the sender in Letter B will be an ok option?
Old Aug 16, 2005 | 11:38 PM
swansong04's Avatar
just my .02
TRAVIST
well there is no cutting cooler lines or drilling holes in my suggestions either .. it's funny i did extensive reading on here and on other fourms and i didnt read in one plce where is was suggested to put the sensor in the test ports , guys selling you the gauges say to put it there because it is an easy place to put the sensor .. dosn't mean it is the correct place to put it !! i am no tranny expert but i m sure there is a few on the board . and i am sure they would not suggest using the test ports .. only M H O
G
Old Aug 16, 2005 | 11:52 PM
david_4x4's Avatar
I'm not sure about the test ports either, but...
I'm always open for opinions.
If the test posrts are a bad idea, where in the pan should I tap it? towards the front, side...?
Old Aug 16, 2005 | 11:59 PM
swansong04's Avatar
here is some good reading for you all ... from dtt fourm
http://www.dieseltrans.com/phpBB/viewtopic.php?t=558
Old Aug 17, 2005 | 12:11 AM
david_4x4's Avatar
So it would seem the tranny cooler line is the way to go.
Ie: This way?
Old Aug 17, 2005 | 06:35 AM
Graphite600's Avatar
This obviously is not a do it yourself project, right?????? What tools are needed, and what are the steps in doing this, please give lots of detail!
Old Aug 17, 2005 | 09:17 AM
david_4x4's Avatar
It is a do it yourself project.
I've been leary of doing it myself, but since there is a lacking supply of shops to install the stuff. I'm pretty much left to doing it on my own. I keep researching and getting my ducks in a row. Asking questions that I need, covering all directions, and take my time. I'm fairly confident that a person who hates drilling into metal and wiring up stuff taht I can do it.
Old Aug 17, 2005 | 10:31 AM
nonford's Avatar
That tranny in line cooler seems nice, but I heard many complain of leaking after its done. I too am stuck as to where I will hook up my sensor for the trans. I may just go ahead and put it in the "B" test port as shown in the above pic and see how that works out. Is the in line tran just a unscrew and then screw in the new line or is there cutting involved? I hate cutting a perfect non leaking line.
