dragstrip
dragstrip
Well got home from another day at the track still in the 14s but low 14s at 98mph now is there something I am missing some piece of the puzzle I am not seeing or doing right is my turbo not big enough do I need injectors do I need different programming I have smarty set at #9 moderate tqman stock auto trans still holding together dont know if doing trans effects 1/4 mile time EGTs1450 just think for the money I have put into it I would at least seen the high 13's by now how bout it what is it what are the magic parts got 3 weeks before track closes 4 the year or build up 4 2008
You are going to need a built transmission, tighter TC to get into the 13s with your mods. My transmission/tc combination with tc lockup switch was worth at least 1 sec in the 1/4 if not more.
well low 14s with a 8000lbs truck dont seem to shabby to me. What did it do stock? or did you try it. I have no help for you but am curious at how you launch it. I have not been to a track but have tried it a bit on the street and I have alot of lag before the real power takes over. I just feel like any good times I might get would be really tainted by a bad take off. Also do you run in 4wheel drive for traction?
I am running a 13.309 with quad x2 race stacker and smarty beta 4.4 sw#9 and tq lock up switch helps alot probably .4-.5 seconds off your e/t. This leaving in 4 high at 10-15lbs of boost. You definetly have high-mid 13s in that truck.
thanks 4 your input I think I got the wife convinced on the way home that I need to do the trans thats no BS she even noticed the trans was shifting really wierd
I get the why does this thing shift like crud all the time from the old lady but, she's not convinced enought that I need an aftermarket trans. and need to spend 5k on parts for it. Her suggestion is its under warranty take it back to the dealer and get it fixed
I am running the new x2 from quadzilla on lvl 5 pressure only with smarty on sw #9 duration and timing only. Heres the link for a lockup switch and this will help to prolong the life of your stock trans.
https://www.dieseltruckresource.com/...ht=lock+switch
Fastest 4wd in the country is still running a stock transfer case in their truck. But it is a 2nd gen. I have read that the nadp truck has broke a transfer case or two though.
I'd bet you could drop a second off your E.T.s with those changes.
I have a lockup on my truck we do ours a different way on our trucks but that will work on his year model and since the post and explination was already their i figured it would be good info for him to have.
