Dr. P
Old May 27, 2008 | 08:36 PM
Striper's Avatar
Dr. P
My rail pressure will drop then recover somewhat as tranny shifts when using beta 4.4 and 4.2 with a stock pump. When it hits overdrive, it will drop all the way to 13k and slowly come back as RPM's increase. I was planning on an upgraded CP3 but I was told that Dr. P box will help this by a very reputable person on here.
Is there anyone out there using this pressure box? Does it increase overall pressure or just help it ramp quicker? Any thoughts?
Old May 28, 2008 | 11:40 AM
Striper's Avatar
Nobody uses this?
Old May 28, 2008 | 01:51 PM
O.T's Avatar
O.T
I have used the Dr P pressure box 2018>? Thinking it was the 115hp box.
Raises pressure based on boost numbers.
For me too aggressive, and I got tonnes of injector rattle.
o.
Old May 28, 2008 | 01:59 PM
molalla1ton's Avatar
I have used the 2021 box, they call it the tripple play it has 3 settings, off, 50hp, 100hp (I think), anyway the 50 hp was not too aggressive but the higher hp was, I stacked it w/smarty same issues as onetun.
Striper's Avatar
o.
So would it be better to just invest in a modded pump?
Old May 28, 2008 | 02:14 PM
stang's Avatar
Dr P they can tune the box how ever you want it, it works great
Old May 28, 2008 | 03:13 PM
O.T's Avatar
O.T
A pressure box is a good investment. If you are seeing 13k and better you should see an improvment with a MP-8, EZ, Dr.P.
Having a modded pump will help the cause, not sure what kind of wait these days.
You can use the P/B before and after modded pump....and there is no down time.
Old May 28, 2008 | 05:07 PM
MegaMagoo3500's Avatar
I ran the DR.P 2017(85hp/170ft/tq) for 20,000km before I stacked it with my Edge W/Att It worked real good for towing nice smooth power. Once I added the Edge, the DR.P gave me that little bit extra in top end when really hammering on it. I dont have any fuel pressure gauge yet but one is in the works so I cant give you any numbers but I know I havnt starved the ol CTD of fuel yet!
Old May 29, 2008 | 02:34 PM
Striper's Avatar
I just found a good deal on a used Stage 3 100hp. Should have it by next week. Looking forward to it. Hopefully now I can wait on modding my pump.
Old May 29, 2008 | 02:48 PM
mainiac's Avatar
i use the dr.p with my smarty. theres is no question it works. i run a rail pressure and it raises pressure right to 25k under light throttle and keeps the rail loaded during my 1/4 runs. nice throttle response difference and top end improvement. i ran it on the dyno and it added about 50 hp on top of the smarty. also, helped fuel milage on back to back testing i did buy 1-2 mpg. i disagree with their 130hp gain, but still a nice piece.
Old May 29, 2008 | 02:58 PM
Striper's Avatar
Do you use a toggle switch to disable or is it on all of the time?
Old May 30, 2008 | 07:09 AM
mainiac's Avatar
it comes with a toggle..3 position...off, tow, performance...only difference being tow cuts pressure at high rpm, performance keeps pressure up.
