Doesnt everyone love a Smoke Video?
I like how when you finally take off it still spews out between the back window and the bed.
With all these burnouts between you 2 or others. Do you go through a lot of rear disk brake pads? I would assume yes but only cause i haven't taken off my rear pads to check mine.
I stopped smoking them once I went to 315's. Just doesn't have the same power. Sure I can brake lock it and keep it going. But usually I just brake lock it until it starts and then let up to take off and burn them. Stock tires, about 30 - 40 feet of rubber smoking, 315's = about 10 - 15 feet if I'm lucky.
I need a QUAD box. Some day... some day.
Rockjeep,
Do you know if a line lock would work on an 05, I assume it would but I couldnt find one for my ford. Also where did you get it? Any burnout is awsome to me, but nothin beats a dually burnout IMO
I custom made the line lock. I got the line lock from jegs. And had to get line adapters to fit the fittingd for the dodge. I then got a four pin trailer plug and plug it into the trailer harness. Its wired in to the running lights. That way I can activate the line lock by turning on the running lights.
Kory
Kory
uuuhhh......
Makes my little smoke look like a neon made it!
This isnt a diesel burnout video but I think it is cool anyway.
http://videos.streetfire.net/Player....8330&kw=34&p=1
These tires are not available to the public and they cost $1000 a piece. But it would be fun to have a set.
http://videos.streetfire.net/Player....6ED0&kw=12&p=7
Originally Posted by DustyRock
I cant get the videos to play when I click on the link. Help.
Is it a Windows ME thing, a setting perhaps? Cant load the last video either. It says connecting and then nothing.....just hangs.
2006BLKMegacab
Jan 19, 2014 12:35 PM
sallyman1
Apr 17, 2009 06:01 PM
