Does SMARTY do pressure fooling?
Old May 10, 2007 | 01:16 PM
PourinDiesel's Avatar
I recently removed my TS Ramifier box that did rail pressure fooling.
With Dual Pumps on do I still need to run this box to take care of the rail pressure fueling? Or should I just run the SMARTY alone?
Thanks for any info....
Old May 10, 2007 | 02:12 PM
t-boe's Avatar
The only Smarty version that does pressure fooling (that I know of) is the Smarty "HOT" version. Other than that it's all timing and duration.
Old May 10, 2007 | 02:13 PM
So I still run the risk of throwing a pressure code with the dual pumps you think?
Old May 10, 2007 | 02:20 PM
t-boe's Avatar
With dual pumps (both being stock) it's more about the volume. I don't think your pressure will go high enough, but I could be wrong.
Old May 10, 2007 | 03:09 PM
cquestad's Avatar
Come on guys...
Smarty does not have to fool anything! It is its own programing. It changes the points that error codes are set...boost for instant...and I am sure pressure too on the new Smarty SW's that have pressure.
I would leave that TS in the mix anyways...just to be able to fine tune your pressure to 27ksi. It might only take 5% of the TS...but still worth it.
Plus...it will always make any truck fuel harder on the bottom.
Old May 10, 2007 | 03:31 PM
judge88's Avatar
i kept my pressure box with the dual pumps. i see gains from it also. dosnt take much.
CTD2001
Feb 14, 2009 07:11 AM
Ghost Ram
Jan 7, 2008 05:15 PM
buddy26
Jan 4, 2008 12:22 PM
CTD03
Jul 24, 2007 12:17 PM
goose2w1
May 25, 2007 09:36 AM
