Does adding boost fooler help spool quicker.
The reason your seeing higher boost is because without a fooler your ECM defuels at 26psi and your wastegate will open. The fooler stops your ECM from defueling which I believe is the reason most guys run them.
The boost fooler does nothing below 28 lbs of boost which is where the factory wastegate opens up. The BF tricks the ECM, which keeps the wastegate closed allowing for more boost, thereby helping with EGT's, which is why most people run them. I can hit 40psi with just a set of 50hp sticks, intake and exhaust. It definately DOES help with EGT's and towing especially. On the '04.5 and up trucks all you need is the BF since it is electronic, on earlier thrucks you need a part to keep the wastegate shut.
The only thing that is going to change your spool up on a stock turbo is...well..changing to another turbo really. An open intake and exhaust MIGHT help a little, but only on higher horsepower trucks as the stock intake is good to 400hp. These turbos spool up pretty quick IMHO, I really think if you want instant gratification you need a supercharger or liquid drugs.
Further...
"Q. Does Smarty do the boost fooling function?
A. Yes, all the the softwares in Smarty have modified boost tables in order to allow higher boost without defuelling.
( Except ;SW # 0 and of course Stock ) No external boost fooler is required!"
From http://www.madselectronics.com/faq.html
well after reading all the replys from the bag of worms i opened. i think the only way the fooler will help me out since it doesnt help to spool quicker. is to use it in the winter months when the grill cover is on, to help cool the EGT's when i have to get on it. Anyone agree ?
cbrahs, I don't have a BF, but it's my understanding that they plug inline to the MAP sensor. So I'm pretty sure all it does is lowers the value that the ECM sees. For electronically controlled wastegate trucks, I would think this would allow a higher boost. I don't know what other parameters it might affect such as fueling, timing, etc. maps, but I think you might be being a bit close-minded.
All a boost fouler does it prevent the map sensor voltage from exceeding a preset limit. It fouls the voltage signal to the ecm so that it never see enough map sensor voltage to open the waste gate. Of course like mentioned this only applies to the later model electronically controlled waste gates.
