do you need upgraded sungear/drum in trans for 5-600 horse?
i was wondering if i needed an upgraded sungear or drum if i were to be at 600 horse tops also will a single disk tc hold up to this power? or should i just get a triple and not worry?
the reason i ask is because my trans went like its gone and im gonna get it rebuilt. ill have to post some pics of me driving a ford to haul it to the trans shop it was a sad day for sure!
thanks
thanks
i was wondering if i needed an upgraded sungear or drum if i were to be at 600 horse tops also will a single disk Tc hold up to this power? or should i just get a triple and not worry?
the reason i ask is because my trans went like its gone and I'm gonna get it rebuilt. ill have to post some pics of me driving a ford to haul it to the trans shop it was a sad day for sure!
thanks
thanks
The planets and drums in the 48re are about as strong as you can get and will hold 600 horse just fine you should get billet input shaft and flex plate. I am running a single disk converter at some where around 750 HP, but I do not run on the street at that hp level probably about 550 HP
Triple disc T/Cs simply have more friction area on the discs to hold the load. They are not more stressful on components than a strong single. What puts the stress on is power (tq/hp). Don't be afraid of the triple. Goerend's makes the best one out there IMO and it is lifetime warranteed.
A billet input and laminated flexplate is a good idea.
Its not the power that breaks things, its the difference is rotational velocity when the clutches engage that stresses the components. Where a single will engage firmly a triple will almost bang in. While the trans definitely needs setup differently for a triple there is a point at which it because exceedingly hard to tune the engagment and maintain the neccessary force to hold.
I'll readily admit you've got a lot more smarts than I on the trannys, but my T/C locks in a lot smoother than the last DTT big single I rode in. However, that could be entirely on the setup too. Mine shifts firm, but not a "bang" shift, or lock up, by any means like that DTT did.
It would seem to me that "holding" the power is ultimately what is wanted in any case and a good triple does that better than a single; especially in a high hp truck and 600 qualifies for that. That said, any version that holds the power is sufficient.
There is no way you can fell it or even measure it very accurately without. Its just the nature of the physics of the equation.
A corrrectly setup VB for the chosen TC is a must or problems ensue with breaking shafts and such. Sames as the OP was asking about upping the clutch count, with a single disk corrrectly set probably not a big deal as both the TC clutch and clutch packs will absord the acceleration and neither get hurt. Add a triple in there and the tendency to spin thru the directs increases, especially at lower pressures in normal driving.
im really debating on what to get!
Could have, enough other factors contribute that nothing is a given. A corrrectly setup triple is hard to beat without a doubt. A single gives you a bit more leeway to play with pressures and such. Its really a personal choice.
nvr-enuf
May 10, 2011 02:49 PM
1985cucv
29
Jun 22, 2010 06:26 PM
CapnRam
Jan 4, 2010 12:46 PM
1985cucv
18
Jun 22, 2009 06:24 AM
1985cucv
May 18, 2009 08:35 PM
