Do I wait for Death Wobble, or cure it now?
Old Apr 26, 2012 | 06:40 PM
dadwolf2's Avatar
I have a 2005 4x4 with only 50k on it and except for a little right pull, it seems to drive just fine. I use the truck mainly to tow a trailer or to put my truck camper on it and use it on vacations and have no plans on selling it.
So do I just wait for DW to happen (while on vacation), or do I spend some money now and nip it in the bud? Your opinons?
Old Apr 26, 2012 | 07:32 PM
06RAM2500's Avatar
Fix it fairly soon.
Old Apr 26, 2012 | 08:37 PM
eastmentCTD600's Avatar
the following is my experience with death wobble.
04.5 with 100k on the clock, no death wobble, never even a hint, stock tires, no lift.
Steering box was wore out (should have installed steering box brace when the truck was new). I knew my tie rod and drag link were going to wear out someday and my steering box was beaten to death so I had to get a refubished box (Red Head Steering Gear). I thought I'd replace everything at once. So I ordered the 2008+ steering components and an aftermarket stabilizer from Bilstein (pressure adjustable stabilizer).
I put the new steering gear + box brace, stablizer, & 2008 steering tie rod and drag link. Drove truck, serious death wobble!
The cause of the death wobble was the stablizer, after I installed it the nitrogen pressurized reservior somehow leaked (valve stem leaked) and the stablizer became a poor damper.
Removed 2008 steering tie rod and drag link, put stock 04.5 inverted Y setup with stock steering stablizer back on. No death wobble. Now 120k mi later everything is still fine, no wobble.
The point is, if you have death wobble I'd first check the steering stabilizer.
I'll put the 08+ tie rod and drag link bck on once I get a factory steering stabilizer for the 08+ trucks.
Old Apr 26, 2012 | 09:16 PM
dadwolf2's Avatar
Two posts and it's a perfect example of the dilemma I feel. Get if fixed soon vs my truck was stock and fine....until I "spent $$ on the fix".
Old Apr 26, 2012 | 09:26 PM
TxDiesel007's Avatar
id fix it as first signs of wobble...
it veering off to the side might just be alignment... mine gave at 200K, and the whole front end was gone.. at 65 mph wobble hit... did it once, did it right, and so far so good..
used moog replacements, bilstein shocks, and stabilizer...
Old Apr 26, 2012 | 10:03 PM
jballou's Avatar
Not everyone gets the wobble as far as I can tell. Just replace parts as they wear out. Or throw down the $ all at once.
Old Apr 26, 2012 | 10:36 PM
torquefan's Avatar
Not sure what your plans might be as far as what parts to upgrade or replace, but if it was mine I think I would order up a steering box brace to install as preventive maintenance, and call it good for now. I think those are good for protecting your steering gear from wear, as well as adding rigidity to the structure. I don't think I would go as far as to start replacing ball joints or tie rods yet, until they were worn out of spec. That's just me.
Old Apr 27, 2012 | 12:03 PM
dadwolf2's Avatar
I had talked to a local truck shop and they were trying to talk me into the Carli front end kit and Mopar 8.5 steering upgrade kit. After I fell off my chair from the sticker shock I told them that I would have to think about it.
I already installed the steering brace and I think I'm going to go with this suggestion...unless I win at the casino
Old Apr 29, 2012 | 01:04 PM
Lost Lake's Avatar
You may never get death wobble because nobody is sure what causes it. If ANYONE was sure, they'd sell the repair by the train car load.
I had it so bad I was afraid to drive my truck. It was a death trap. I got rid of it by doing things others have done that didn't help. What that tells me is that a multitude of things can enhance it, and several things can mask it.
I think if you changed your caster to 5 degrees negative you would get death wobble right away. Caster would be my first start, getting 3.5 to 5 degrees positive is a great start.
After that I'd make sure my joints are good, my stabilizer is good and my steering box is good. All that stuff helps control it, but doesn't cause it. Plenty of vehicles drive down the road just great with no steering stabilizer, worn out ball joints, slopping steering gear boxes, worn out shocks, bad tie rod ends, and they don't have death wobble.
The geometry of the design is the problem, added to the straight axle. Bigger tires accentuate it, as does lift (which changes caster) and rear loads (caster again).
Good luck.
Old Apr 29, 2012 | 09:56 PM
jimbo486's Avatar
I did all the fixes to my dad's '06 4x4. Carli leveling kit, McQuay Norris Extreme series balljoints, Bilstein 5100 stabilizer, PSC steering box stabilizer, Carli high mount stabilizer (Bilstein 7100) and a Carli track bar all with 35" ProComp Xtreme ATs. Words straight from the guys at Carli are that we covered everything that they have found to cause the dreaded death wobble. Alignment was done after all components and tires were installed with no caster adjustment that I'm aware of (we know the guys at the shop we go to and we talk about everything they're doing while they're making adjustments) and not a single bit of death wobble here.
Old Apr 29, 2012 | 10:19 PM
alboy's Avatar
IT might be interesting to know what tire make is most prevelent with the DW.I have 63000 miles, tow heavy and never had a problem other than a replaced steering box at 15000 miles,have always run the AT TOYOS.
Old Apr 30, 2012 | 12:23 PM
torquefan's Avatar
Good luck.
Good post. I agree with those points, and will add one too. Tires. I think front tires can be a real trigger, especially from stuff I have read on here. Out of balance, worn out, or too light of a load range can all create the resonance that the steering will amplify until it turns into a full-blown death wobble.
Many who suffer from DW also seem to me to be those who use BF Goodrich A/T tires, and others here have mentioned a possible connection too. I believe they are a load range D configuration that often get installed on our trucks, so I'm not sure whether that model of tire or the load range has more to do with it.
Old Apr 30, 2012 | 04:33 PM
soulezoo's Avatar
DTR 1st Sergeant
My DW came from big worn out mudders... probably out of balance during wear. They were E rated.
I've only had the DW with those tires.
Old Apr 30, 2012 | 05:35 PM
Lost Lake's Avatar
My death wobble was during the time I ran BFG AT tires, but they were load range E. They were 305's which is probably a bit wide for the rim. I had to keep them aired to 80 lbs and if they weren't rotated at least every 5,000 miles they would start to cause DW.
Old May 7, 2012 | 08:47 PM
13jeeps's Avatar
Death wobble happens on these trucks because of the solid front end and coil springs. DW is never caused by a bad steering stabilizer as the stabilizer's function is to reduce, control, and mask front end vibration. DW is most often caused by worn track bars, followed by worn tie rods, ball joints, improper alignment, out of round or balance tires, worn steering box and control arm bushings. Often the cause of DW is not one component that is obviously bad but multiple worn parts that individually are not worn enough to warant replacement necessarily but when taken togegher they harmonize to amplify small road input into what is known as death wobble. With enough experience you can anticipate and prevent DW with a sudden input to counter road inputs; a stiff stab on the brakes or a twich of the steering wheel can often prevent the onset of DW but only to a point. The only real cure to DW is a properly maintained front end. Keep in mind that the bigger you go the easier you will get DW.
