Ditching Banks, what next?
Old Sep 2, 2006 | 02:23 AM
bradmulvey's Avatar
I m going away from my 6 gun and want a better unit that doent always play it so safe. So I was kinda hoping that the edge juice was a scanner also, but I havent seen anything on that. I am sick of going to the dealership to clear and check codes. Lately since I have installed my Banks High Ram, my check engine light is always on and it reads 0633,2609, 0336 every freaking time! So what are my options?
thanks in advance
brad
Old Sep 2, 2006 | 06:08 AM
OT-OF-Here's Avatar
What next??
thanks in advance
brad
I assume you have a built tranny or HD clutch. If I were starting all over again I'd definitely go with the latest TST w/ user adj timing and also the fueling feature which is like having a EZ or VAC3.1 basically all built in one. It's probably the most complete single unit a person could have and it is dang near infinitely adjustable so you can use it if you need it as far as power and it is undetectable for dealer visits,... take it off. Sweet!
Old Sep 2, 2006 | 07:39 PM
dakotar's Avatar
bully dog
id go with the the triple dog from bully dog, the crazy larry program is sweet! you can clear your own codes and can return it to stock any time you want.
Old Sep 4, 2006 | 12:07 AM
973604x4's Avatar
P0336 Crankshaft Position Sensor Performance
P0633 SKIM Key Not Programmed in PCM
P2609 Intake Air Heater System Performance
sounds like banks
Edge Juice/Attitude, Bullydog Triple Dog, TST, and Quadzilla are all good options.
You might want to get your code throwing situation fixed first...i know i would.
Old Sep 4, 2006 | 03:05 AM
BigDan's Avatar
Good choice on ditching Bank's
I cant believe nobody has suggested the Smarty. It does everything you asked and then some. It will add 170+HP, Clear codes, adjust for tire size, Internet updateable, ect.
If you want more info Search Smarty
I just got it in the mail yesterday and its awesome!
MARF75
Nov 28, 2023 12:57 AM
Firstgenfanatic
Jul 9, 2011 03:17 PM
CarcajouCummins
71
Jul 4, 2007 03:06 PM
jb903
Mar 7, 2007 08:28 AM
