Dipricol guages
Old Dec 5, 2006 | 01:53 PM
StrokeThis2500's Avatar
Dipricol guages
anybody have pics of the dipricol guages installed in the a-pillar and pics in the center consule or dash. also how to install egt guage
Old Dec 5, 2006 | 01:58 PM
goodeyesniper75's Avatar
if you go to photos and search it you will find tons
Old Dec 5, 2006 | 02:13 PM
dodgezilla04's Avatar
you'll get many different instructions for drilling and tapping for the thermocouple. the safest manner, is to remove the manifold from the engine and do the work on a bench, blow out the chips, and reinstall the manifold.
you can drop the turbo, place a piece of cardboard over the turbine inlet to prevent chips from falling in, drill and tap then.
what i did, was tape over 3/4 of the tail pipe, have all my tools, drills, goggles, gloves, etc ready. start the truck, and start drilling and tapping. the exhaust escaping will blow the chips at you, not into the turbo.
i had 22k miles on the turbo after i did this, and when i upgraded to a bigger turbo, i looked at the turbine for signs of any damage and there was none.
Old Dec 5, 2006 | 03:42 PM
how difficult is it to remove the manifold? what are the steps for that
Old Dec 5, 2006 | 03:44 PM
MrSlug's Avatar
Another good tip is to coat your drill bit with heavy grease in addition to drilling while the motor is running. The metal shavings will stick to the grease coating.
Old Dec 5, 2006 | 03:48 PM
P.J's Avatar
P.J
I think that is waaaaaaay more work that is necessary. Hundreds of us have done it by either unbolting the turbo or the method mentioned above. I used the grease on the bit/tap, then magnet, then shop vac method. Works like a charm. This was the second truck I've done, did my new one in less than 15 minutes start to finish. You will need either a short (pneumatic) or right angle drill. It can be tight in there, or you can remove the inner fender well for better access.
Old Dec 5, 2006 | 03:53 PM
Hey thanks for the tips....
Old Dec 5, 2006 | 04:30 PM
i mounted my thermocouple straight up and down, didnt go to the side. just put it as close to the center as i could. 2+ years and 25k miles. no problem
Old Dec 5, 2006 | 08:00 PM
53 willys's Avatar
X2 on the extra work, I did mine the same as P.J... I removed my inner fender well too. ( did not have a drill small enough to do it any other way) it's really easy
Old Dec 7, 2006 | 11:25 PM
gsbrockman's Avatar
I currently run the EDGE Juice w/Attitude (built-in gauges) but do run a DiPricol Fuel Pressure Gauge in an SRT/10 A-Pillar mount.
Greg
Old Dec 7, 2006 | 11:34 PM
CowboyDave's Avatar
I have been considering them, anyone have any pictures taken at night. I would like to know how they look compared with th dashboard. Thanks, Dave.
NukleusX's Avatar
Muted User
I dont have any pictures of mine online as of yet.
As for the pyro probe, I was lucky enough to find a good deal on a new manifold on eBay for about $80 that happened to be pre-drilled. Could have just done what people here are saying, but at the time I wanted experience with it, so I went gung ho and did it.
Old Dec 8, 2006 | 03:49 PM
CowboyDave's Avatar
Bueller......................................Buell er?
Old Dec 8, 2006 | 04:31 PM
P.J's Avatar
P.J
He's sick.
My best friend's sister's boyfriend's
brother's girlfriend heard from this
guy who knows this kid who's going
with a girl who saw Ferris pass-out
at 31 Flavors last night. I guess it's pretty serious.
Old Dec 8, 2006 | 04:37 PM
HayHauler1's Avatar
Thumbs up
P.J
Did the gauge install change the location of your grab handle? It looks like it is farther up the A-Pillar than mine is with no gauges yet. I am looking at the same set of gauges you have.
Thanks,
Hay
