Dimmer
Old Mar 24, 2011 | 08:56 PM
jrdperformance's Avatar
Dimmer
I just installed dual pod auto meter boost and pyro. my question is can you dim the guages. I have a 06 2500 and the gauges are autometer c2 if any help would be awesome.
Thanks
Old Mar 24, 2011 | 09:24 PM
Bankdude's Avatar
I drew the power for the lights off of the dimmer switch for the factory guages. The autometers are a bit brighter but do dim in concert with the factorys lights when using the dimmer switch. Tapped into the wire behind the switch. Not to hard to get at.
I have an 03 so I cant tell you which wire for the 06 but I am sure someone will advise you here.
Genos says: Orange wire with brown stripe for 2006 and 2009 models (pin #4).
Check out the tip from Genos:
http://www.genosgarage.com/installat...lTips03-05.pdf
Old Mar 25, 2011 | 11:25 AM
tryNto's Avatar
Did mine like above...
chucktownsend5
14
Mar 22, 2020 02:40 PM
bdog
May 6, 2018 04:33 PM
jonrob
Jun 26, 2005 01:18 PM
wgingg
Jan 20, 2005 08:13 PM
ckennedy
Nov 15, 2004 06:54 PM
