different larry programs
scary larry seems to cut out at 3500 rpm the pl goes to 3950 no speed limiter and yes it does torque management delete to code is on the back of the triple dog also to run scary larry SAFELY you would need a upgraded lift pump,turbo,trans,and possible injectors and cp3 NOT for stock trucks
throttle sensitivity yes I think the pl tune is a little better if you use it only for track time due to the added pressure it calls for. NOT designed for stock injector tips
chopper9451
Aug 6, 2009 08:47 AM
julang
Dec 30, 2007 09:11 AM
HeberRam
Mar 30, 2007 05:37 PM
RyeThomas
24
Mar 23, 2007 06:12 AM
Snojumper
34
Mar 18, 2007 12:27 PM
