Diff. Fluid?
I want to replace my diff fluid front & back. Is there anybody running redline fluid? If so what kind/weights? Reason being is I get redline cheeper and I am tryin to save a few bucks.
If redlines no good, ill prob. end up running amsoil. Im open to all suggestions, fire away...
I run Amsoil, but I'm a bit biased, as I sell it. I also think its a much better fluid than the others. If you are going to run synthetic, my recommendation is Amsoil 75w110 severe gear... Its compatible with limited slips, and open differentials.
Scott
Scott
I run Redline and I think it's the best. Changed mine at 15k now have 66k and everything is still clean. About every 10k I check and clean the small amount of mud off the magnets. I use the 75-90 gear oil in the diffs, C+ATF in the transfer case and MTL in 6 speed. I think its the best bang for your buck. I plan to change it all again somewhere between 75 and 100k and probably never change it again. I also use Redline 10w40 motor oil in my wifes toyota, daughters Kia and my Yamaha Rhino.
afate45
Jun 7, 2014 12:08 AM
banana
Dec 1, 2009 11:44 PM
icrider
Sep 27, 2006 03:10 PM
