Dick Cepek 20x9's
Dick Cepek 20x9's
So I finally ordered my wheels. I'm getting Dick Cepek 20x9 DC-1 black rims,
http://www.dickcepek.com/DC1_Black.html
And Mickey Thompson Baja ATZ Radials, 305-55-20.
http://www.mickeythompsontires.com/t...=BajaATZRadial
The rims have a -13 offset, I still don't know if they will rub or not, I guess I'll have to wait and see. Does anyone else have this size tire with a -13 offset? I have no lift or leveling kit, and I also have BW fender flares and mud flaps.
Thanks for your help!
i ended up getting rid of wheels with neg offset to fit 35's-went with an 8.5" wide wheel with +6mm offset. tires fit, wheels look good tucked in but still had to do some fender flare trimming in the wheel well- good luck.
The negative offset sticks them out further and with the wide wheel and tire it would have a chance of rubbing. Hopefully they will fit, my guess is they will but it will be close. Post some pics when you get them. They should look great though.
the negative offset does push the wheel out further which helps big tires clear your control arms but if you don't have about 6" of lift it greatly increases your chance of rubbing the rear fender well. generally wheels with 5"-6" of bs and a pos offset work best for clearing big tires with truck at stock height or 2"-4" of lift.
CumminsDreamin
46
Jul 23, 2006 10:37 AM
lightening ram
Jul 2, 2006 02:02 PM
lightening ram
Jun 21, 2006 08:19 AM
223 rules
May 19, 2006 12:47 PM
