Dented by rear bumper...
Dented my rear bumper...
Slid into a darn tree tonight, and but a nice dent in my bumper. Anyone have a replacement, or know where I could get a good deal on one? I don't think it's in a spot that's easily pounded out - it's just to the right of the centerline on the 'thin' part of the bumper.
I think I'm gonna cry.
That sucks!
The stocker new will set you back $5-600.
Check with you local wrecking yard.
LKQ is nationwide and had almost new takoffs for $250. The step pad may be a different color though.
Don't feel to bad buddy, last month I was headed down my iced over driveway( a long hill) and I hit the brakes to hard, ABS must of kicked in cause the back end started sliding to my left. I knicked my rear bumper on a pine tree at the bottom of the hill. Put a small scrape on it, which buffed out but it also left a little dent. I didn't even try pounding it out. It gives my truck character.
I seen somewhere( don't remember where) but it's a dent remover. It's like a suction cup deal that you tighten over the dent then yank it off. I don't know if it works or where you can get them but it's just a suggestion.
If you want to hear a dent story that will make you cry just ask me.
I got a oops that wasn't supposed to happen.
I decided I was going to take the rack off the top of my truck by myself. Well it started with the spare tire. I decided I was going to roll it off the side of the shell instead of the back like I always do
Anyways, it rolled down the side and hit the flared part of the bed putting a nice dent in it, more like a crease. That was right before a show that I was doing as well.
Man, I wish I knew what I was thinking when I did it.... That will make you cry for sure...
Yeah - I'll probably end up with an aftermarket one - like I said before I found 'em on eBay for $275.
BUT
I borrowed a couple of hammers and dollies from a neighbor and was actually able to get 'some' of the dent out by just pounding on it - still attached to the truck. So, since I need to remove the bumper to replace it anyway, I figure I'll remove the bumper and pound on it some more where I can get some better leverage. If it turns out decent, fine. And if not, I'll replace it.
I've spent all day apologizing to the truck for doing what I did - I hope it forgives me :-)
BUT
this is true i had my truck fish tail on me on wet roads about a month ago and ended up sliding into the pole with the drivers side just infront of the bumper dented the quarter panel and bent the bumper back a little pushed the dent out some but every time i see it i start kicking myself and apologizing to my truck. bald tires and wet road don't go well together.
Aftermarket bumpers.
There's a guy in my area that does some nice work in aluminum. I'm hoping he can crank one out for $6-700 bucks. I want it to extend further out and back and especially to take a mild hit without denting.
I dented the one on my '00 pretty bad and got a replacement from a company called Keystone. Lifetime warranty and it ran me $260 (I got a little discount because I work for an insurance company, IIRC). Looked great right thru when I traded it in on my '05. Their number is 800-322-2415.
