Crud!!! Edge juice troubles.....
Old Aug 28, 2005 | 12:04 AM
bigman's Avatar
My juice with attitude has problems. The egt readout reads 1000 degrees at idle and 1500 going 35 mph. Of course it backs down and i get the annoying alarm. Has anyone had this happen? Is there a way to reset it? It will be pain to uninstall it and send it back. CRUD!! I had the BDDL on last my last cummins maybe i should go back. Are the programmers more reliable? Any tips on plugging the egt probe while it goes back? Thanks
Old Aug 28, 2005 | 07:23 AM
ftltmp's Avatar
I have not had any trouble w/ mine, when you hooked up your pyro you didn't get the wires crossed at the harness did you? just a suggestion.
Old Aug 28, 2005 | 09:27 AM
bigman's Avatar
It has worked very well for 6 weeks now. I think its connected the way it should be. Thanks anyway.
Old Aug 28, 2005 | 09:44 AM
Dorkweed's Avatar
Muted User
From: "The Peoples Republic of Illinois".....behind enemy lines
I had the same problem. I called Edge and went through a procedure (disconnecting the pyrometer) that they told me to do over the phone. I told them what the Attitude said without the pryo on. Anyhow, they sent me a new pyrometer. I figured it would be a least a week for the new pyro to get to me so I reconnected the old one. Worked fine after that. Never put the new pyro on even after it came in the mail. About 1-1.5 months later though, the Level setting in the upper right corner of the Attitude would change from whatever level I had it set on down to 0 (stock) and back again!!! All by itself!!! Called Edge and they sent me a new box for under the hood. It got here about 3 weeks ago, I installed it and all is fine now. I think both problems were Juice related and not Attitude related. Give them a call>
Old Aug 29, 2005 | 09:31 AM
cquestad's Avatar
Bigman,
Take it off...send it back. You wanted the Hot Juice update anyways!
They will take care of you.
Old Aug 29, 2005 | 04:24 PM
docrob's Avatar
had the same problem. level would change back and forth on its own. leave the probe where it is, or install 1/8 npt plug. copper anti-sieze is also a good idea. good up to 1800 F
Old Sep 20, 2005 | 02:25 PM
Gotlift01's Avatar
My dad has an 05 that I just installed the attitude w/ juice on, and his EGT numbers a freaking whacky!!! It jumps all over the place getting as high as 1900* just idling down the rode. It will jump as much as 1000* at times and is never consistant..........guess it's time to call edge and make them fix the dang thing!!!
CowRazy
Oct 28, 2007 04:00 PM
belgianmagic
Feb 15, 2007 04:55 PM
HappyCamper
Jul 17, 2006 11:58 PM
razor6
22
Jan 20, 2006 03:43 PM
usmc2311
Aug 9, 2005 04:01 PM
