CP3/Lift Pump Needed?
Old Jun 10, 2011 | 08:58 PM
075point9's Avatar
Like my sig. says, I've got 50 hp injectors and at some point I want to get either a Smarty Sr. or EFILive tuning (depending on availability) and twins. I'm trying to plan out my budget and I'm wondering if I'd need a lift pump, a CP3 upgrade, or both? Anybody got a similar setup? If I had twins I'd want to be able to turn up the Smarty, not be limited by rail pressure.
All thoughts appreciated.
Old Jun 11, 2011 | 07:12 AM
RyeThomas's Avatar
Winner winner chicken dinner!
A lift pump is always a good idea. As far as injector pump, get a rail gauge and keep an eye on it. It will show you when you need a cp3 upgrade. I would go lift first. JMO
Old Jun 11, 2011 | 09:04 AM
Spooler's Avatar
LP is a good idea. The CP3 is not needed until you get up in injector size and that is when you get over 100hp injectors is when that need may arise.
Old Jun 11, 2011 | 05:54 PM
075point9's Avatar
Ok thanks guys. One less thing to think about.
Old Jun 12, 2011 | 04:40 PM
no_6_oh_no's Avatar
Anything more than stock really needs an LP upgrade so plan on it. Get FASS\AD depending on your likes and add a 2um filter just in front of the CP-3 or you will just trash your system and new parts. Depending on how much power you want you can reuse the OE cannister and stock filter for water seperation, or by pass the OE cannister for more fuel. If you bypass you will need a standalone water seperator in the system somewhere.
If you want to use the capability of the injectors and Smarty you will have to upgrade the CP-3. A bag of parts will get you so far and then it will be a worked over pump. Much over 100 HP and the stock CP-3 will be your roadblock.
adamsmarshall
13
Oct 7, 2008 06:54 PM
Jethro6213
19
Jul 11, 2008 11:59 AM
pullin hard
Mar 18, 2008 03:57 PM
BADBOWTIE
28
Jul 14, 2007 02:36 PM
megacabrule
33
May 10, 2007 01:07 PM
