Confirm TNT timing
Old Dec 5, 2009 | 03:24 PM
JJPage's Avatar
Question Confirm TNT timing
After reading approximately 50 threads on this subject, can someone please confirm that I have this correct.
#1 12*
#4 16*
#3 18*
#2 21*
I have thought this to be correct, and have it writen as such in my Smarty box, need re-assurance.
Thanks in advance, Jess
Old Dec 5, 2009 | 05:04 PM
doug60's Avatar
That looks right to me.
Old Dec 5, 2009 | 05:51 PM
bbbxcursion's Avatar
Subscribed
Old Dec 5, 2009 | 07:35 PM
JJPage's Avatar
Thanks doug60. I see your running the TNT-R, is there much difference in power between the Revo TNT and TNT-R, or is it just the 4k rpm factor.
Been thinking about having Bob send me the TNT-R, but I want to be able to go back to my other programs (411, betas, etc), if it doesn't work out. Right now I can go back and forth from Revo TNT to the older programs at will. The Revo TNT does not always play nice with my truck, so when I get fed up with it's quirks, I go back to the earlier software.
I have been playing with timing 4 and 1 today (tnt), and so far no mis-steps... I did notice it spools up quicker, or seemed to, with less timing, can this be right?
Old Dec 6, 2009 | 07:37 AM
doug60's Avatar
Im running timing 4 for that reason .
spool up is quicker /less smoke
I have only had the TNTr so I cant say .
But most say the R is more street friendly.
Old Dec 6, 2009 | 09:29 AM
5POINT9's Avatar
how can you state those timing remarks? the timing changes based on numerous tables and maps, constantly changes.
doesn't make sense?
Old Dec 6, 2009 | 09:34 AM
1985cucv's Avatar
what is the normal timing degrees on the smarty sr are they the same. sorry to highjack
Old Dec 6, 2009 | 10:52 AM
JJPage's Avatar
I thought I was imagining making boost sooner with less timing, but also higher boost at cruise. Thanks again for re-affirming my conclusion.
doesn't make sense?
After doing a search on this subject, I found a thread by "Mulisha", titled "Smarty TNT Owner's look at this". I believe it is probably the max timing through the rpm curve.
Old Dec 6, 2009 | 11:09 PM
Brokenarrow's Avatar
Thought the Smarty timing was a mystery? Actually thought all the chips for CR trucks were a mystery, nobody wanted to give out info?
Old Dec 7, 2009 | 11:26 AM
RD TRCTR's Avatar
Anything can be determined with an oscilloscope!
Old Dec 7, 2009 | 03:48 PM
homewrecker's Avatar
A memeber on another board used a scanner to acquire those numbers. As far as I know they are correct. Can't wait to see what Super Revo holds in store for adjustability.
Old Dec 8, 2009 | 12:41 AM
dodgediesel's Avatar
Super Revo??????
Old Dec 8, 2009 | 01:32 AM
ramman's Avatar
How much timming rattle do you get with the #4 ? I have some espically at low boost conditions with #1 and all the burned piston post lately I'm trying to keep it together as I just got the CR/Ford conversion running GREAT.
Old Dec 8, 2009 | 07:15 AM
MikeyB's Avatar
Originally Posted by dodgediesel
Super Revo??????
Bob mentioned on another site about a Super Revo coming down the pipeline. No details yet.
MikeyB
Old Dec 8, 2009 | 12:01 PM
AH64ID's Avatar
#1 12*
#4 16*
#3 18*
#2 21*
I would guess thats the max seen on the scanner? Also is there a way to tell if thats the pre-event or the main event? I have heard stock the main event is only 2* max.
