Commander reading 0 psi fuel pressure.
Old Jun 30, 2008 | 03:15 PM
OR Mega Cab's Avatar
I've had the truck to the dealer to have the lift pump tested and they say it is within spec. Rail pressure never dips indicating it is not getting enough fuel. Do you think the FP unit is bad?
Thx
Old Jun 30, 2008 | 04:52 PM
qzilla's Avatar
I don't guess I understand that?
Check the installation of the sensor on the FP side. Make sure you did not use a ton of teflon tape, that can cause the sensor to not get a ground and it won't work.
Old Jun 30, 2008 | 07:09 PM
It worked fine for the first 8-10 months after it was installed. I will check the grounding of the sensor, but I don't believe that is an issue.
I was under the impression that if the lift pump is going out and starving the CP3 then the rail pressure would drop randomly as the CP3 runs out of fuel. Is this not correct?
38 Cigarette
16
Aug 28, 2015 11:27 PM
mullishacrew
Mar 18, 2012 12:41 PM
ClassA4x4
Jul 25, 2011 02:17 PM
schamran
Dec 14, 2009 08:20 PM
Dave88LX
15
Sep 4, 2006 09:30 PM
