Commander question
Old May 12, 2007 | 06:42 PM
PG4x4's Avatar
Commander question
1. Will the commander control the power setting for my bully dog?
2. Can I change tire size with it?
3. Am I able to manually add my own boost sensor and have it wired into the commander? It seems like all digital guages stop reading boost at 40psi.
4. How does it read the trans temp? via the factory sensor?
5. Does it come with a egt probe or do I have to buy that seperate?
Old May 12, 2007 | 07:23 PM
Luvnacumns's Avatar
1.. Not sure??
2. Nope
3. Nope it's tapped into the map sensor. So no manual boost have to go analog for that.
4. Temperature probe..
5. Yes..
Shane
Old May 13, 2007 | 12:34 AM
qzilla's Avatar
1.) Bullydog module, yes. Programmer, NO.
2. No
3.) Not your boost sensor but, we have an analog adapter that goes from 0-102psi that should cover you. Boost will read up to 44-46psi at most on a stock MAP sensor.
4.) 1/8 npt probe
5.)Included
Old May 13, 2007 | 02:30 PM
PG4x4's Avatar
I have the bully dog triple dog so thats a no then for that?
Old May 13, 2007 | 02:57 PM
Luvnacumns's Avatar
Yes sir!!!!!!
stock03
Nov 9, 2006 11:27 PM
skydiver41
Sep 1, 2006 11:53 PM
HDBeauty
Aug 26, 2006 09:24 PM
RAMROD2006
Aug 24, 2006 10:47 AM
cumminsboy
Oct 25, 2004 09:35 PM
