combininb lift kits
combininb lift kits
i currently have the 2" leveling kit but my 315'70'17's still rub (wrong offset for wheels) is there a kit i could add to this setup to add say 2" more. i dont want to go 4" or bigger. i would only like to add 2" to the front and rear.
Are you running 2" spacers or leveling coils? If you are running spacers, a leveling coil combined with the spacer might work, and you can add the mini spring packs to the rear from Carli or Lorenz...
if you have 2" spacer, you can add 2" springs or just get 4" springs. with 4" of lift, you will need pitman arm, track bar bracket, sway bar drop blocks, possibly front shocks, and will be very close to needing longer control arms. you'll be better off buying a complete kit.
TheNeckasaurus
Oct 13, 2010 08:16 PM
customizedcreat
May 19, 2010 01:44 PM
LLoTuner
Apr 9, 2008 11:28 PM
Igor
Aug 6, 2007 09:39 AM
