Cold Air Intakes using factory lower elbow
My airaid intake utilizes the stock lower elbow by the turbo. For those of you that have installed one of these or the S&B, did you remove the white plastic vanes in the lower elbow or did you leave them in place? I did and I'm not sure if it should have been removed.
They dont help anything!! infact all they do is look like they should be there, other than that they are as useless as a boar with mammaries!
they do not help performance... they probably don't HURT performance untill you get to a certain level, but you'll get better performance without them whan you will with...
I would have to see actual flow charts that could PROVE what you guys are saying!! I have seen Flow Charts on Intakes/Exhausts and beleive me these veins are NOT going to create a problem in this 3"-4" Intake Tubing with the stock compressor!!!! I work with massive AirFlow Units everyday and I know that anything that can help DIRECT the flow of Air/Water will help in the efficiency of that substance. As said before, mine will be staying!
it's a sound suppression thing, not a performance thing
That is true because the air veins direct the air instead of letting the air slam against the bottom portion of the Intake Tube---Which would create a slight swirl-----which ='s NOISE. So therefore you are right in the sound department. AFTERMARKET-----$$$$$$$$$-----and what does everyone want in an Intake---To hear that TURBO SCREAM!!!!!!
