Coating on exhaust stack
Old Jul 30, 2010 | 01:27 AM
Sasqoutch's Avatar
Question Coating on exhaust stack
Im going to be getting my front custom ranchhand destroy anything bumper re-powder coated to a grey color to match the grey strip on the bottom of the truck (top is white). Iv had my cat d6 5" stack on for about a year and the stock paint is starting to fade. How do you think powder coating will hold up to constant exhaust tempature changes over the next few years? I have access to many different kinds of coatings so if anyone has a suggestion please let me know.
Old Jul 30, 2010 | 09:16 AM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
I have 6" stainless stacks on my dually and I've used the infared temperature gun at work and they run around 400-700 degrees in the bed area where they join the tee coming from underneath. That's just after getting off the freeway so I'm sure they would get hotter if I had a decent load. Choose your coatings for those temps.
The biggest 'killer' of painted or powdercoated surfaces on those stacks or pipes is the thermal expansion and cooling.
The stretch from cold to incredibly hot really puts a strain on the coating and most of the time causes it to crack and peel off even if the surface is prepared because the coating tends to finish curing over time and gets brittle.
Have you considered chroming?
Old Aug 1, 2010 | 09:15 AM
Sasqoutch's Avatar
Thank you for the reply cdennyb, you bring up a good point. No not interested in doing chrome. Now that you meantion it powdercoating dosent seem like a good option for that. other exhaust parts usally dont come powder coated, mostlikely for that reason.
Old Aug 1, 2010 | 10:34 AM
.boB's Avatar
PC just can't handle the heat. Get a good ceramic coating. Not only looks good, but blocks some of the heat transfer. Make sure you find a company that coats them inside and out - like Jet Hot.
jk6140
16
Aug 13, 2009 07:55 AM
D45
18
Dec 29, 2008 09:37 PM
12VBLacKCLouD
Mar 4, 2008 12:09 PM
jdr160
Jan 31, 2008 09:57 AM
jmccart
Mar 18, 2007 09:28 PM
