Check engine light problem Need help
Old Apr 29, 2007 | 10:01 AM
czechdiesel's Avatar
Hi to everybody, I need help, I installed Quadzilla XZT module with Commamnder in my truck and when I started engine first time I get the check engine light and engine run very poorly. I find out that problem was bad connection on fuel pressure sensor, my fault I don't pushed OEM connector all the way to the Quadzilla harness. I fix it and engine run great,
but I can't get ride off the check engine light. When I scanned, on my scanner I get error message and if I try to erased anyway I get same error message on scanner screen. My scanner is a OBD II.
Any idea how to get check engine light ? Truck is a 2007 5.9 L CTD.
My scanner is probably 6 years old, not sure if any changes was done in new scanners. Please any idea will help, I don't like to go back to dealer doing that. I will need to take all out.
M
Old Apr 29, 2007 | 10:19 AM
RamWheelsBy4's Avatar
First the CEL should go off after 4 or 5 start and run sequences if actual problem is no longer present.
DC switched from OBDII to ScanBUS interfaces in 2006 I think, that is probablly why you older OBDII scanner won't work.
I don't think you have any thing to really worry about, codes from improper connections happen often. Maybe you can find a parts supply with a ScanBUS diagnostic tool to read and clear the code(s).
Old Apr 29, 2007 | 10:26 AM
973604x4's Avatar
You local autozone should scan and clear codes for free.
Old Apr 29, 2007 | 10:47 AM
Is this scan Bus interfaces you are talking about ?
http://cgi.ebay.com/ebaymotors/GS300...QQcmdZViewItem
czech
Old Apr 29, 2007 | 10:51 AM
czech
Uh, yes CanBUS not ScanBUS, must be too early in the morning to have fingers and alcohol fogged brain working together.
DC ScanBus tool and CanBUS interfaces all ran together, need coffee
hot tempered
May 12, 2012 10:04 PM
buddy26
Feb 15, 2008 12:17 PM
choppers555
Oct 16, 2007 12:29 PM
alltimelow1
Apr 6, 2005 07:28 PM
WDS41
Sep 14, 2003 08:32 AM
