changing to billet shafts
Old Mar 28, 2005 | 05:26 AM
Dave04600's Avatar
Last night I was doing a little holeshot and it seems that I snapped a shaft in the trans. I'm planning on changing out all the shafts and putting in a suncoast xtreme rebuild kit. I havent been into a 48re except for the tc and vb. I was just looking for some advice when I take this thing apart if there is anything special I need to know or if I need any special tools. I have rebuilt trannys before, I'm just not sure if I need to get any spring compressors or anything.
Old Mar 28, 2005 | 07:33 AM
pcburnout's Avatar
You proably snap your input shaft as you have a aftermarket TC and VB .
Bill over at DTT recommend at time of build for mine to put billet in or I would snap off stock one with new upgrades. She's tightly wound now.
Your tranny is no more then a over sized old style 727 Toc. Flight very simple tranny.
Pull pump, lossen front band, pull front and direct clutch out and change input.
Rear output is in overdrive housing which just pulls off back of tranny I myself have never gone trough it.
Give DTT a call great people to work with they sell Billet input and output shafts.
http://www.dieseltrans.com
Good luck!
Old Mar 28, 2005 | 09:42 AM
PowerstrokeThis's Avatar
Re: changing to billet shafts
Well I can't help you out much on tellin you what to watch out for when you rebuild the tranny. But what I can tell you is that I have the full out race tranny from suncoast on my 1998.5 dodge and it works great, it's like driven a totally different truck.
Old Mar 28, 2005 | 01:06 PM
Mcmopar's Avatar
You will need some spring compressors, and some measurement tools to set up the OD unit. DO NOT take the OD apart until you read a manual-there is a very stong spring compressed with 700-800 lbs of pressure on it. If you pull the wrong c-clip you have a "wild spring" flying around!!!
Old Mar 28, 2005 | 07:24 PM
greyrig05's Avatar
dave
what kind of horsepower and torque are you running??
and how high did you spool it up?
just wondering, i'm getting worried about mine
Twogun
Feb 19, 2006 10:41 PM
RowJ
Competition / Pulls / OffRoad
25
Aug 26, 2005 09:04 PM
GO 4LO
Jun 10, 2005 07:07 PM
Goggleyed
Dec 24, 2004 05:12 AM
gunracer1
Dec 19, 2003 08:45 AM
