Cam shaft replacment
Old May 7, 2011 | 12:22 AM
07nbcowboy06's Avatar
I have a question how do the wooden dowels rods hold the roller's in place? i don't understand it. i am wanting to replace my cam but i want to understand every thing first. can someone help me out.
Old May 7, 2011 | 08:53 AM
gunnie's Avatar
The lifters have a cupped shape to them on top it is about 1/2 in diameter, when you push the dowel pins into the cup shape on top of them, pressure from the dowel allows you to pull them up about an inch or so then you tie the dowel pins for each cylinders lifters together with rubber bands so they don't drop back into the lifter bore and obstruct the cam removal or replacement. As long as the dowels are seated well in the top of the lifters this works perfectly.
Old May 7, 2011 | 12:46 PM
thank you i didnt unerstand it i am tryin to find the best cam for my 07 dodge. what are some good ones
Old May 7, 2011 | 01:16 PM
gunnie's Avatar
doing a cam swap on one of these is a pretty big deal, nothing that can't be accomplished but I would definitely recommend doing alot of research on this site before tackling the project just so there are no surprises
Old May 7, 2011 | 05:29 PM
Blueboy's Avatar
That is a bad question, Ive seen guys start cam wars on whos
is the best. Go in search look for cam threads.
Old May 10, 2011 | 11:27 AM
.boB's Avatar
Good cam depends on a lot of things. Before looking at cam specs, decide what your ultimate goal is, mods done and planned, and use of the engine. You may find the stock cam to be the best choice for you.
Old May 12, 2011 | 08:41 PM
Nsomniac05's Avatar
X2. When I did mine, I had it at a shop on base where you pay to use the lift and tools and do your own work, it was supposed to only take 6 hours for the valve springs, and 12 hours for the cam, but considering work schedules, and after dropping a valve lock into an oil galley, breaking off a center punch in the #6 cylinder, trashing my front cover [harmonic balancer] seal, cutting, and welding the subframe, and having to figure out alot on my own, the bill for keeping the truck their was almost $150. I honestly don't think it was a difficult job, just very tedious for one set of hands, and expect it to take far longer than anticipated.
Old May 14, 2011 | 09:48 AM
carl48's Avatar
like bob said a lot depends on what you are trying to acomplish. i wanted to get rid of the in-cylinder egr for better mpg for that the pdr or colt was the best. i see the kids for high hp and rpm use the hamilton
Old May 14, 2011 | 11:15 PM
sr4440's Avatar
keeping this thread on track, i was looking at doing this but the "Miller Tool Kit 8502" wooden dowels are $350 and i am just going to change my cam not go into business changing cams. Is there something other then the "wooden dowels" or something other then the miller kit?
Joe
Old May 15, 2011 | 09:39 AM
carl48's Avatar
no but the woden dowels were easy to make
Old May 15, 2011 | 12:25 PM
torquefan's Avatar
Joe
Wow, I wasn't even aware you could get the dowels in a kit. I just bought some dowelling at the hardware store, 1/2" I think, cut them into lengths about 12 inches or so, and slotted one end of each. They have worked great on at least half a dozen trucks.
Old May 15, 2011 | 07:31 PM
Nsomniac05's Avatar
yep, 1/2" diameter dowel rod from Lowes, cut into 12" sections and beveled on the business end, jam it into the lifters, tap a couple of times with something heavy, pull them up, and rubber-band them together. Easiest part of the install. Just be sure they're in there snug, because if they fall, there is no tray like the old 5.9s that will catch them.
Old May 16, 2011 | 08:24 AM
sr4440's Avatar
1st of all, thank you, I would have probably spent the money on the tools. (you can't have too many!)
I know this sounds stupid and i am sure i could figure it out once i got the engine apart, but could you post a pic of the beveled end?
Joe
Old May 17, 2011 | 05:39 AM
Nsomniac05's Avatar
What helped me figure it out, is if you pull the push rod out, and look at the end that goes in the lifter, that should give you an idea about how the dowel should look. No exact science.
Old May 17, 2011 | 05:47 AM
sr4440's Avatar
Thanks
Joe
etn550
Apr 1, 2010 12:12 PM
Det 1
17
Dec 22, 2009 08:32 AM
AH64ID
Jan 18, 2009 04:59 PM
Buckshotmckee
Dec 17, 2004 03:25 PM
reddawg
Apr 13, 2004 06:11 PM
