Buying a Torque Converter
Old Feb 20, 2008 | 09:22 PM
CDoskocil9's Avatar
Is it a bad idea to buy just a Torque Converter??? I think I want to go with a single disk from DTT any suggestions??? If I use TowHaul on the 06 doesnt this increase line pressure??? So could I do just a TC and no Valvebody by the way the most power my truck will ever have is a programmer Smarty or BullyDog.... Im new to the transmission business so any help is appreciated.....
Old Feb 20, 2008 | 10:06 PM
durasnack's Avatar
wouldn't be good money spent unless you buy atleast both converter and valve body...why DTT anyway?
Old Feb 20, 2008 | 10:15 PM
Luvnacumns's Avatar
I would call dave at goerend or dusty at htt they are really knowledge able... Or I can give you Dave at Ultimate's number or e-mail... He will floor you on tranny knowledge... I ask simple question's to keep it from going over my head...lol
Old Feb 21, 2008 | 03:17 AM
jwb600's Avatar
I would lean more towards a converter/valve body together. I would give talk to these people www.htstransmissions.com
Old Feb 21, 2008 | 09:10 AM
CDoskocil9's Avatar
Thanks guys Im going to call HTS today and I have Dave at Ultimate number too... Will report back
Old Feb 21, 2008 | 09:59 AM
durasnack's Avatar
HTS dealer just down the road from you....and you know his number
Old Feb 21, 2008 | 12:04 PM
megaboom's Avatar
does hts offer a tc? i ddnt see it ontheir website.....they do have a **** good price for a valve body though
Old Feb 21, 2008 | 12:15 PM
soulezoo's Avatar
DTR 1st Sergeant
I believe, and can be wrong, that HTS sources their TC's from Suncoast.
Old Feb 21, 2008 | 02:12 PM
rufushusky's Avatar
I think you are right, HTS does transmissions and valve bodies but uses suncoast converters.
Old Feb 21, 2008 | 02:19 PM
metalbasher's Avatar
I got a quote on a triple disc and a valve body and the price was reasonable. Cheaper for me than buying from the local Canadian guys.
Old Feb 21, 2008 | 03:07 PM
jwb600's Avatar
yes dusty uses a suncoast converter and I have to say they hold up very well from what ive seen
Old Feb 21, 2008 | 08:10 PM
92'1stGen's Avatar
There's a guy on here that has only a triple or single disc TC in his trans and he was running a quad on the 100 hp setting and is now running a smarty jr., I assume on the 100 hp setting too. If I remember correctly he also had 35's on it too. I believe his truck was an 05 and he talked to Dave at Goerend about getting a TC and VB. But, I think due to the change over from a cable driven throttle to a electronic throttle and the trans unable to determine the proper pressures for shifting in the trans with a built trans starting in the 05 and up year's, that Dave just recommended he get a TC. Now there is shift enhancer's you can get so the trans knows when to shift with an aftermarket VB but I have heard even those aren't helping for some people. It all depends on what you plan to do though, I only plan to run a smarty jr., with the usual exhaust/air mods. I'd give Dave at Goerends, or Dusty at HTS a call. From what I hear they both know there stuff very well.
Old Feb 21, 2008 | 09:03 PM
durasnack's Avatar
what he said
Old Feb 23, 2008 | 11:39 AM
dzltrqcrzy's Avatar
Dang 1stGen, you have a good memory ! I beleive I'm that guy.
I've been running Dave's single disc for 3yrs and 50k miles on quad 100hp and now Smarty jr on 100hp.
At the begining all I wanted was to get rid of the stock TC and get something tighter. I didn't plan on adding hp. A few weeks on this site changed that :-)
When I decided to add power I contacted Dave regarding adding a VB (the TC was already in). At the time, he wasn't too familar with how the computer controlled the line pressure thru the servo on the trans, so he suggested I ran the truck as is. No sign of slippage or anything in 3 years with no towing to speak of however (2000lb trailer+bike)
Under hard acceleration from a stop, the tires will spin before any clutch in the trans will. Going up steep passes in CO and flooring it from 60mph produces no slippage either :-) If I was towing, I'd buy the 'enhancer'
Give Dave a call, tell him what you want to do and I'll set you up with just the right stuff.
Old Feb 23, 2008 | 03:16 PM
92'1stGen's Avatar
Yeah that would be you, I remembered your mods and your talk with Dave, but couldn't remember your name. Recently I've been looking through the Goerend posts on the websites, trying to decided on just a TC or a TC & a VB. My mod's are going to be pretty close to what your's are, probably just a smarty Jr.
