Bullydog Triple Dog
Bullydog Triple Dog
Hi new to forum been reading for a while. Had a 03 5.9 just got a 07 5.9 and phoned Bullydog they said program not out yet but should be in about a month for 07.I put a post on another thread asking if they could detect the program if you bring it back to dealer someone posted they can but Bullydog says if you put it back to stock they cant tell. The truck seems faster than the 03 I pinned it and once turbo spooled up tires broke lose and in stock on my 03 it would not do this.Had a Edge on 03 cant wait to try the BDTD on the 07.
they can tell, unless they are changing the programming for 07. The bullydog when returned to stock removes keystrokes. If your truck has 30,000 miles and you return the BD back to stock to go to the dealer, it will say you have had something like 2 or 3 or 5 keystrokes, when it should be a couple thousand.
Thats just what it does on current trucks. If you are going in for something simple, then a simple scan wont find it. If you are going in for something big and a cummins rep has to come into town, you may as well fess up because they will find out. For the most part, you are fine.
I LOVED my bullydog. i am trying so hard to sell my edge juice right now to go back to my bullydog. i loved it and i want it back.
V2.2.5a Feb, 2006
Customer Downloader
Ford New Part Number VXDB1xx.HEX 2005 Excursion
Fixed Multiple Vehicle Part Lock
Dodge New Flash 253253X.XAE 2005
New Flash 203252X.XAI 2004
Resolved Erasing of Key Cycles, and Fuel Used
Recalibrated 2004.5-2005.5 Vehicles
New Feature 2005 Vehicle Options Available!
: Idle Up Enable
: Auto Door Lock/Unlock Enable
: Set Headlamp Delay Time
: Horn Chirp on Lock Enable
: Optical Chirp on Lock Enable
: Unlock Driver Door on First Press Enable
All Improved Upgrade Procedure
samgovol
Feb 26, 2006 10:08 AM
Luvnacumns
13
Jan 14, 2006 10:28 PM
