Bully Dog Race Program
Old Aug 2, 2007 | 10:12 AM
Bud Kunz's Avatar
Figured we would start a new one so we don't hijack ppe's thread.
I wrote a program race program for a couple of guys with pressure hard coded in (meaning not adjustable on the fly). I am pretty sure I named them all V2.3.PL. It is a pretty rough version so I didn't want to pass it out to a bunch of people. I am working on adding this into Crazy Larry and will be on one of the next Crazy Larry Beta versions I send out.
By the way if anyone else wants the Latest Crazy Larry beta I wrote it is live and released on the Update Agent as Crazy Larry V2.4.1. Hope that clears things up.
Old Aug 2, 2007 | 10:24 AM
morkable's Avatar
Does this increase the RPM? Will it fuel all the way to top RPM? Will it work on a 03?
Thanks
Kevin
Old Aug 2, 2007 | 10:25 AM
cranked_dodge's Avatar
yes it works great on the 03 just put it on my truck and its amazing
CReed's Avatar
Ya that v2.3.PL. was a bit rought buddy but that thing flew if you werent scared to push the loud pedal!!! then turn it back down to performance on the fly before you got out of the throttle, or it would try and keep going whether you wanted to or not.
Old Aug 2, 2007 | 10:27 AM
CReed's Avatar
This new beta is alot smoother buddy and i mean alot keep up the good work.
Old Aug 2, 2007 | 01:09 PM
Pitz's Avatar
The new beta is running great, can't wait to see what the pressure does!
Old Aug 2, 2007 | 03:46 PM
Rpainter's Avatar
I think it is funny how quickly prople start crying when you dont take about the great ppe downloader for 850.00 I will pass
Old Aug 2, 2007 | 03:50 PM
05 Thunder Beas's Avatar
I second that! It will be awesome with the pressure added! Thanks Bud!
Old Aug 2, 2007 | 05:07 PM
CrashCade's Avatar
Who started crying? I just thought it was funny that the thread was about ppe and it changed over to Bully Dog.
Old Aug 4, 2007 | 01:16 PM
Pack Mule's Avatar
so which one is hotter the v.2.3.PL or the v.2.4.B?? i think i got the last one right. cause like everyone else, i want more.
Old Aug 4, 2007 | 02:19 PM
Rpainter's Avatar
2.3 pl is hotter it has hard written in the program 27000 psi rail pressure with the program I keep throwing the high rail pressure code I am going to dig out my quad box and see if that helps drain the rail a little?
Old Aug 4, 2007 | 02:53 PM
Pack Mule's Avatar
so it probablly wouldn't be recomended to run a pressure box with the 2.3pl what about fueling??? does it fuel harder?? my little engine light keeps comin on when i'm WOT at about 3000rpm but it goes off after i turn the truck off and back on. and how do i get this 2.3.PL???? i currently am having trouble getting the charger lit at lower rpm. it's not a quickspool of anykind it's an old sledpuller66.
Old Aug 4, 2007 | 03:36 PM
Rpainter's Avatar
no presssure boxes he told me that this program was for racing and aftermarket tips only.it fuels very hard but I will warn you that program was designed for a 04.5 one guy put it on a 06 and after 4000 rpms the truck would not idle down had to put in neutral and cut it off what code are you getting?I am runninga silver bullet with no problems do you still have stock injectors??
Old Aug 4, 2007 | 09:20 PM
Pack Mule's Avatar
it's not throwing anykind of code. i do the dtc scan and nothing shows up. and i've got 90hp DDP tips. i'm wanting a silver bullet but can't afford one yet, i'm also gonna invest in a set of flux sticks. but for now i'm sending john my cp3 to get it fixed. i put it on and couldn't tell a lick of difference in power so he's gonna go thru it and find my problem. hopefully i can be fast again. what about tst??? could i stack a TST box with this program???
Old Aug 4, 2007 | 10:53 PM
Rpainter's Avatar
only if it is the tst with adjustable timing feature
