Which Booster Fuel pump??? for '05
Old Mar 24, 2006 | 02:59 PM
Igor's Avatar
Hey guys,
I need to get a booster fuel pump for my '05. From what I understand, if I put a booster pump inline and leave my lift pump in the tank, even if it fails, the booster should be able to pull fuel through it, and feed the CP3 w/o problems. I'm just wondering what you guys are doing with '05s as far as the fuel pump upgrade goes?
Here is what I have:
Edge Hot Juice w/attitude
MP-8 Ramifier
tripple disk TC, VB, and looking for flexplate
and mods in sig.
I don't plan on using the full chip power of course until a turbo upgrade and perhaps a few more things, but, I want to do the fuel pump only once.
Thanks a lot guys,
Igor.
Old Mar 24, 2006 | 03:40 PM
staarma's Avatar
If you only want to do it once then drop the tank and install the 3/8's pickup tube and the FASS unit bypassing your stock limp pump. You won't be sorry.
Old Mar 24, 2006 | 04:12 PM
Blast Chamber's Avatar
I agree with dropping the tank and adding a new pickup tube, as well as doing the TDR vent mod and taking care of the two "gasser" hose barbs. As for which aftermarket lift pump to use, the FASS-2 is a fine unit, with the Walbro GSL392 also being an affordable alternative.
Bradleysram
19
May 12, 2009 08:36 AM
PupleDiesel
Apr 27, 2009 08:26 PM
barngal6
Jan 15, 2009 08:10 PM
robox
Sep 30, 2005 07:15 PM
supercharger
Dec 4, 2004 09:52 PM
