Which Boost guage ?
Old Apr 7, 2004 | 06:19 PM
lucey's Avatar
Which Boost guage ?
I'm curious which Boost guage would be better, 0-35 or 0-60.
Old Apr 7, 2004 | 06:21 PM
amartinson's Avatar
Depends on what your future plans are. 0-35 is fine for a stock truck, but won't be enough if you slap on some bombs down the road.
Old Apr 7, 2004 | 09:19 PM
lucey's Avatar
Guage
When using the 35psi will the guage be right at the end on a stock truck or is there some room for future mild bombing or should i just get the 60 now and be done with it. How close to the end of the guage ?
Old Apr 8, 2004 | 08:20 AM
jt's Avatar
jt
If you get the lower one the sweep distance of the gauge is larger, therfore the increments have bigger spaces between them. I installed the 0-60 gauge. I ordered my gauges through Mark Craig, they match the factory gauges nicely. I got the boost and egt with the steering colum mount.
James
Old Apr 8, 2004 | 08:55 AM
Breakin Loose's Avatar
I had this same question. If you put on some air intake upgrade (BHAF) and then a full 4" exhaust (turbo back) and then add a fueling box, is the 0-35 boost guage enough?
Old Apr 8, 2004 | 04:58 PM
doug's Avatar
consider the limitations of the intercooler and head gasket, valve train (you don't want to float valves with too much head pressure). Personally I think 0-50 is a good number, but I happen to like the dual Westachs -- boost and EGT in the same analog face. one gauge on an SRT-10 pillar.
Old Apr 8, 2004 | 05:03 PM
I'm thinking the same way. I have my SRT-10 post and am wanting to order the Westach combo. I'm just not sure if the 0-35 is enough, guess I'll go with the 0-60. The 0-50 would be nice.
Old Apr 8, 2004 | 05:08 PM
doug's Avatar
Westach has a 0-50. Genos garage
here is the link
Old Apr 8, 2004 | 05:13 PM
Then that's what I'm getting. Guess the wife will have to go without shoes this month.
Old Apr 8, 2004 | 05:32 PM
doug's Avatar
I'm behind on the SRT-10 post. whats the cost and is this a new pillar that includes a new grab handle? do I assume you get this from the dealer?
Old Apr 8, 2004 | 05:34 PM
amartinson's Avatar
WOW!!
If you could teach me the secret behind that one, I'd be driving a new truck like you!!
Only been married 7 years, what am I doing wrong?
Old Apr 8, 2004 | 05:35 PM
You can get the SRT-10 post through the dealer (part #ZL39TL2-AA). They might tell you that it's a weird number, but they CAN get it. It replaces the whole pillar and includes the handle. It's also the stock color already.
Old Apr 8, 2004 | 07:39 PM
lucey's Avatar
SRT 10 ?
Is this SRT10 for one, two or three guages ? Also i suppose a guy can get the 0-35 and always upgrade later. I found the Autometer Ultra Lite guages for 40.00 US (53.00 CDN) so really peanuts in the grans scheme of things.
Old Apr 8, 2004 | 08:06 PM
Smokeman's Avatar
The SRT-10 pillar is for one guage only. Just put one in.
Brian
Old Apr 8, 2004 | 08:25 PM
doug's Avatar
or put in one dual guage
